ARCHIVED: [DEAD ROM] ThundeROM V1.8.3 4/5/2011
Status
Not open for further replies.
Yes, the ap2sd within the rom is working fine on 1.5
Apps2sd was not fully supported in 1.5 it acted like it. You are going to have to either wipe all data or do a way with the partition.
I have done testing on apps2sd for long time now and i can say unless i find away to change a couple things ThundeROM will not support apps2sd because of the high risk to sdcard. I have ran apps2sd oon several phones and never had any problems that's not the case when it comes to the optimus. I highly,highly suggest nobody to run apps2sd because you will run into issues sooner or later. I have 5 dead sdcards to prove it,these were not cheap knock off sdcards.We have completely removed anything to do with apps2sd in 1.6 and won't be adding in back. The rom is completely tweaked to give as much room as possible without causing problems. Once/if we find a better way to include apps2sd we will.Sorry for any miss understanding but we have said all along that apps2sd is not fully supported.
I was running a2sd with no problem in 1.5, should I really uninstall or just stop using it and use titatium instead if i want to move something over? or try to not move things over to the sd card at all? thanks...
OK, back to Thunder recovery and getting the same error. Would turning ap2sd off, then turning it back on within darktremors ap2sd help cause this?
busybox a2sd help
busybox a2sd remove
busybox a2sd install
I see above...... Thanks
If you made a ext partition it won't be mounted anymore,i removed all support for apps2sd.
ThunderRom wallpaper
I like the stock thunderrom wallpaper but I want to change it to something different sometimes. I can't find the pic of the stock wallpaper, so if I change it where would I be able to find it to get it back?
Thanks!
Thanks!
See change log for version 1.6 in post #1
thank god! i've been rom flash itchy for a while now!
thanks all involved in creating and updating thunderom
does it matter that i installed nicks gingerbread theme over 1.5? will I have to reinstall it or anything?
rebooting after reflashing the amon based recovery, re-partitioning my sdcard, wiping everything & then flashing ThundeROM 1.6
How did you guys get the notification bar to be transparent? I cracked open services.jar but couldn't find the file/line to change on my own.
Im not completely sure on that, go to sleep one night praying that it happens and then it does.lol Im not the one that was able to pull that off.;)
You would have to reinstall the theme after flashing,we can keep it from wiping all your data but themes will always get replaced.
Maybe I'm ignorant as to its purpose, but would the improved memory management in 1.6 reduce the need for MinFreeManager, or would you still recommend it?
EDIT: Haha! Nice timing lichan. Right as I was typing it . . .
Status
kingteekay
