sclarktay4
- Nov 27, 2010
- 24
- 8
- 0
Does any one have a factory sprint image for lg optimus s. I need to take my phone back to sprint and my memory card that had my nand backup will not load.
You can flash it no problem and the gingerbread keyboard does not go away.
I've been having a couple problems with my phone that have recently popped up and I wanted to see if anyone else is having issues like these or knows what I can do to fix them.
1. My SD card will randomly eject it's self. I know this becuase when i try to use the apps that have been moved to the SD card the phone can't find them after the SD card has been reloaded. It seems to happen most often around the time I lock or unlock my phone. At first it was only happening about once a week but not it seems like a every 2 to 3 day thing. I bought a patroit 16 gig microSDHC from new egg and that's the one that keeps ejecting while the phone is in use.
2. My phone will not turn on the display sometimes after I either have a intensive process running and then lock my phone. Some in the past 2 night this has happened while I was asleep and left my phone on the chaerger without me running anything intensive.
I am running the lastest ThunedROM and have the over clock widget on my phone just for fun. Even though I know it is already OCed, I just wanted to take the lower frequency and change it back to 128 MHz.
Love this ROM btw and even though I'm having these issues it still beat the stock ROM by far xD. Thanks for any help you can offer.
See the "Unroot and return to stock" thread:Does any one have a factory sprint image for lg optimus s. I need to take my phone back to sprint and my memory card that had my nand backup will not load.
Have you tried to reformat your SD card using the phone? That seems to fix it for most people. For the display, no clue.
Both issues are well documented issues with this phone. Nothing to do with the ROM or your specific phone or your specific setup. A stock, fresh out of the box phone has these issues. The SD card one is fixed in the most recent update from Sprint which the next version of ThundeROM is built off. That will be coming out soon, so that covers the SD issue but the problem with the phone not waking up is still a bit of a mystery although we have it captured in logcat and some other tools so we're hoping to crack that someday.
hey i had 3g connectivity before i applied the rom and now i dont. any ideas?
No, the Android system/hardware is trying to copy at fast speed's. I believe they are working on a fix for the next TR, but until then the only fix is to buy a Class 4 or more SD card.question, with this rom ive been having the SD card problem where it unmounts itself, is there a quick fix?
No, it will KEEP asking... but the update will not start without you doing so. Virgin Mobile is signed with Sprint, so it is the same update.to start, great mod works very well. I have one issue tho. I am running a Virgin Mobile Optimus and after i install this RoM it keeps asking me to update the system? Is there a way to stop this constantly popping up? Do I update or not? Thanks for the help![]()
