KYsmith, I installed Handcent and it brought back the standard android keyboard with the numbers on the top keys. Or have I just had too many beers today?![]()
Sorry if this is a repeat question. i looked and couldn't find anything.
Will thunderom work with the VC version?
From what I've read and understood ThunderROM, nROM, and LEGO rom are only compatible w/ V8 and V9 updates, so I think the answer to your question is no.
VCRom is your only option for now, but I'm hopeful for the VC upgrade when the ROM's come out w/ a new release. I haven't heard if thats the developers plans or not yet thought.
i tired to apply a theme on swype and lost it completely...do i have to install the rom again or is there a way to get my swype back?
did you try holding down the input box and selecting input method then android keyboard??? I had the same problem a while back and it was just that the input wasn't changed for handcent..
Allen369, please read through the forums some. This has been asked and answered time and time again. The update is not compatible with any rom yet. You will need to go back to stock to update. There is a fix to stop the update message if you search a little. And if you do update after going to stock, thunder rom 1.6.2 and earlier versions wont work with it.
This is incorrect. nRom has been updated to be compatible with the VC update. There is also VC Rom and another one that was released today. This thread is supposed to be about tRom though, which from what I read is also in the process of being updated.![]()
With he latest nRom you cannot install the VC update over nRom. nRom was built around VC.
I actually restored my originaly image. accepted the update came up with the same error as Allen369 on the recovery screen. Choose reboot system and it came back up. Ran z4root and it rooted, then booted to thunderom. No nag and everything is good to go. One thing I did not do was wipe the suggested folders.
right. but you can install it after updating to vc. people who updated aren't stuck with stock![]()
question. if TR 1.5 worked really good for me, and i want to flash back down to 1.5 from 1.6.2, do i need to wipe my stuff?
can i get some help?
