Disable home keys/unlock screen vibration
Has anyone figured out how to disable the vibration when you press one of the 4 capacitive keys below the screen? Turning off haptic feedback only disables vibration on a screen touch, but does not disable vibration on pressing the home keys.
Also, anyone know how to disable the vibration on the unlock screen? I cannot seem to find a setting for this as well.
Go to sounds in settings then hold on tap on general click edit you will find all the required options
Code:
I eventually worked out how to switch off all vibrations for my Lenovo TAB 2, Android 5.1 by going to Sound & notification, then clicking the cog next to General (under 'Predefined profiles') and unchecking 'Vibrate on touch' - hope that helps! :)
Yes
Go to settings - sound and notification - other sound - vibrate on touch
Disable " vibrate on touch"
This will surely help you
I disabled the second set of vibrations by either going to settings- sound- vibration strength or pressing volume and click the bars in the upper right. Android 6.0 LG G4. Hope that helps.
Hello guys . I m using my moto phone and after doing a bit of searching i have managed to turn off vibration on the home screen. 1. Go Settings. 2. select Sound 3. search for Other Sounds option ( usually situated under Power Up Sound button )
4. you can see Dial Pad Tones , Screen Locking Sounds , Touch Sounds, Vibrate on Tap options.
5. Toggle them on or off as you wish😀😀😀
I hope this helps. Thank you guys
Set tap on vibrate, to zero. :cool:
luigui443
