Discussion For - Root, Recovery, ROM without touching a computer
How does thundeROM look. I'm willing to try the root process n all. Just wanna know what are the advantages of this. Oh yeah n how will the home screen look
Sent from my LG OPTIMUS T using Tapatalk
Nope. The custom roms at just a great benefit to rooting your device. Feel free to root without a custom rom but definitely look into the benefits. Most of us find it well worth the trouble.
So I followed every step and when it got time to install the rom it said file corrupted. Now everything is gone and I have no idea what to do and my phone is back to factory.
Download the ROM again, put it on the SD card, (might need to download it on your computer, then copy it to the card), and try to flash again.
KSmith, any chance we could get MD5 hashes published for each ROM release?
Thanks for the reply. I ran it again to see if I screwed up but it's still aborting the installation because it says it's bad. I'm going to try your tip.
im having trouble doing this i did everything correct and nothing happend now when i try to do it it says operation not premited
i rooted my phone using unrevoked do you know of any way to unroot or at least how to install the gingerbread on my htc evo?
You have to be more specific. When you try to do WHICH step does it say "operation not permitted"?
This may seem like a dumb question, but will i get my contacts back by following these steps?
Your contacts are synced with google, (as long as you've had sync on since you last changed any contacts). Go check out your gmail account, you'll see you have all your phone contacts there. If you wipe your phone so you can install ThundeROM, it will resync with google once you give it your gmail again.
nickmeredith
