Dismal Battery Life
Knox is tied to android system. So are other few things have the same drain. Doesnt mean its using battery.
But as the picture above shows it says that itself used 14% of the battery assuming I interpreted that correctly
For what it is worth, I've not had any battery issues since the Nougat update.
Same here, in fact, Stand By battery life got better.
I did do a Factory Reset after upgrading to Nougat though, to give it a nice fresh start and it has been smooth sailing since.
I have also noticed the phone doesn't really heat up anymore, when it does it just gets a bit warm but nothing crazy.
amateur_user
