Do You Turn Off Your Phone Regularly?
I do it every day. When I go into work I pop in the extended battery. When I leave work I out the stock battery back in. Battery life on the v10 sucks so I always use the bigger battery while working.
Every night. No reason to get calls in the middle of the night. Last thing I do is shut it off before bed.
Since I have all my work coming in my e-mail I never turn it off - so when I wake up I will be able to check all them instantly :D
rebooting phone is good for device performance, rebooting clears the active thread and restarts it, which helps your mobile to increase it performance...
I never turn off the phone unless it is abnormal. In most cases, the phone will automatically shut down because of insufficient power.
I never turn off my phone. Well, only when something is going wrong, for example when a closed application/process is draining the battery.
I use the do-not-disturb feature to prevent phone calls, texts, and notifications from bothering me. Only Alarms are allowed to make a sound or vibrate. That way, it's my alarm clock.
I do not power down at night, as I use a digital clock app on my nightstand and have the phone in a charging cradle. I keep Wi-Fi on so that it can download updates for apps, sync my cloud files, etc. during the night while I sleep so that I'm not annoyed by my data slowing down during the day for that nonsense.
The only thing I power down for is if for some strange reason I need to remove the SIM or SD card or swap them out. I did this earlier this week when I upgraded the SD card to a faster one with a higher capacity.
I do perform a restart each morning as part of my routine. Not that I've noticed it is needed, but I do know if you go long enough without one, it can cause slowdowns. Therefore, I've made it part of my daily routine. When I am about to jump in the shower, I perform a restart before jumping in. That way, it's ready for the day when I am and I never experience those annoying slowdowns you get from running for 30 days straight without a restart.
I have mine set to reboot automatically at 4am every Friday morning (I don't work until 3pm on Fridays, so if it messes up my alarm, it doesn't matter too much) just because it supposedly helps performance.
My phone is turned on only if it need charging for the battery :D However I turned it off several times when I wanted to avoid any calls during some days.
kalikama1
