Does Note 8 battery good enough for a day???
BB_PP
126
I have used blackberry keyone, s8+ and now note 8. My Note 8 battery is not sufficient for 7am to 9pm! Is it normal ?
Mine and all others in our family do not have an issue. Now, the question is, what the heck are you doing with your phone. Maybe NO phone would last
Mine is poor to bad as well. But I suspect it's due to widgets and the number of apps I have. I still love the phone however.
My battery life is excellent. l can routinely get through a full day without recharging.
Mine averages 12 to 13 hours with roughly 4 to 5 hours SOT. Pixel xl 2 far superior for battery used in identical manner. Only let down so far.
Nothing much! Usual stuff. I am a medium user and getting 3-4 sot with 12-13 hours battery life. Appreciate scteenshots and any help.
I normally take mine off charge around 6am and there's still about 30% left when I put it back on charge around 10pm. That gives me between 4-6 hours screen time.
I'm quite happy with the battery life, I've never been in a situation where I think it might not last me.
I also have excellent battery life, far exceeding my demands for a full day of use.
One place to start is to see if doze is working correctly. And easy way to test is charge the phone up to 100% before you go to bed. Then unplug it and leave it face down (at least if you use AOD) all night. I did that last night with mine, since it'd been quite a while since I'd run that test. Mine was at 98% after 7 hours. BT and Wifi on, location off. If your results are not similar to that, I'd suspect a rouge app(s).
This is what i am looking for
how you use your phone depends on battery use. I unplug mine about 7:30 and recharge at 45% about 5:00. I have it connected to two bluetooth all day, one for calls and the other for music. Don't spend a lot of time surfing, gaming or videos. When I get home and start playing games and reading it goes from 100% to 40% in about four hours, but that is constantly use. Games kill the battery
Screenshot please!!!
My typical day is....
Put on charge around 6.15am til about 7am to 100%
Go to bed around 10.30 -11pm and if it's on less than 80% then just pop on charge for 5 mins, it will lose around 2% overnight so I like to have it on around 85% before sleep.
I usually end the day at 50%, I use my device as a productivity device. email, text, a little social media and phone. I don't play games. I use the camera a lot.
Share Your Screenshots It may help people like me who are straggling with battery life issue.
Daily! At least 6 1/2 plus. Charge 100 percent every night and use throughout the day!
update:
things are getting better as I have transferd my data by backing up previous phone which was keyone. Clean install did the Trick
heritagevine05
