You stated that the Verizon message app also works on tablets, I tried it and it states I have to have Verizon to use it. Crazy I say.Verizon Message+ app will do pop-up texts, and will also allow you to respond from that popup. I use it all the time. And FYI - you don't have to be a Verizon subscriber to use Verizon Message+ app. And it also works on tablets too.
I feel the text pop-up is too fast. It goes away within a few seconds and if you're fast enough to tap it, all it does is take you to the app itself. It would be awesome if you can just respond directly from the pop-up.
Ok. Found fix. You have to loose edge lighting but the reply option is back. //uploads.tapatalk-cdn.com/20170923/020f1deee57f24069c451f4f1244f7f7.jpg
This worked on my Att version!Ok. Found fix. You have to loose edge lighting but the reply option is back. //uploads.tapatalk-cdn.com/20170923/020f1deee57f24069c451f4f1244f7f7.jpg
