Droid not wanting to mount to PC
boyer61
156
5
I have tried everything. It worked about a week ago, Since then i have taken out the battery and SD card to clean it (About 2 days ago) and installed CM 7. I did wipe data and cache when installing CM.
My SD card is mounted on my phone. When i plug my phone in, the computer beeps, saying that it's connected. Phone charges, and everything. On my phone, i see USB Debugging in the notification area. Nothing to do with mounting the the USB to the computer.
I have Windows 7 64 Bit. I already tried unmounting the SD, pulling the battery and SD, waiting for 5 minutes and still nothing.
Any ideas??
CM7 nightlies? If so, which one? I think there was a problem with that in one of the nightlies. Try the stable version 7.0.2
Ok, so i just re installed CM 7.02? (The stable one) and i hooked it up just after i signed in and it works. I'll finish re installing my apps and see how it goes from there.
And now back to square one. Tried to mount it with everything on, OC kernel and all and it won't mount. Im restoring my back up pre installing the kernel and ill see how that goes.
Ok, if anyone can confirm this for me it would be great.
I installed Chevy's 1.25 LV Overclock kernel and i can no longer mount to my PC. When i go to my back up, it'll be back to normal. Can anyone confirm this??
They've mentioned on the CM forums that the way they got it to work was done on the kernel level. So flashing a new kernel will mess up your ability to mount your phone to your PC. There are some kernels that have this fix (Prime's Deprimed kernel), but I don't think Chevy's is one of them.
Reactions: boyer61
imsi
