Droid Turbo: Battery Life
My screen shots from the GSam Battery monitor app show my progress since last full chat. Keep in mind that my Google Music app has also downloaded over 6 GB of mp3 files to my internal storage in the background most of this time. Not bad. Soon I will test the charging time with the Turbo charger when I get down to 10% battery.
My 4g signal strength is -89 dBm
http://tapatalk.imageshack.com/v2/14/11/01/8a699e814110e6fa7e6228396a66bafc.jpg
http://tapatalk.imageshack.com/v2/14/11/01/b80b87092b783fe2af01c7c9bac49418.jpg
Pretty darn good considering the massive file transfers and time kept awake!
Sent Turbo-fast from my bulletproof 64GB Droid Turbo
I feel confident in this phones abilities. I'd be willing to go out for the night with my battery at 20% considering I know it will last.
Sent from my Motorola Droid Turbo
Something people need to get used to is this phone will last hours when it hits 10% or 15%. Usually with my s5 I'd be searching for a charger at 25%. With the turbo u need to realize that %10 is almost an hour of screen on time and probably 10 hours of standby.
The idle drain on this phone, and by idle drain I mean the amount of battery loss that occurs while I'm not using it because I'm sleeping or my phone is literally down, and facing down so that the active display is not constantly running, is definitely not nearly as good as my Droid Maxx. That doesn't mean I don't have multiple things syncing with a fair amount of activity. To be clear, my email is set to auto push- gmail, yahoo, exchange - my WhatsApp is on and I had a lot of messages, my Line App was running and I had numerous messages, my bleacher Report app had numerous stories pushed through, in addition to a few yahoo news feeds, etc.
All I can say is that my phone was unplugged while this activity transpired for approximately 6.5 hours and I woke up with my battery down to 90%. On my Maxx, it would have been closer to 96%-97%.
This was all on Wifi by the way.
On a semi separate topic, I will question though whether this is due to actual battery loss or whether the amount of battery loss is being interpreted more accurately. I question this because I've noticed now in my first 3 days with the phone, that once I hit 50%, and then 40%-30%-20%... so on, it seems to be more consistent than the Maxx. In other words, on my Maxx, once it hit 50%, I always questioned whether that figure was accurately interpreted because it always seemed to drain significantly faster than the first 50%. And at 20% on my Maxx, I would notice a precipitous decline, whereas as on this phone, it seems to continue climbing down at a consistent pace.
This is just what I've noticed over the last few days, but it still seems to translate to inferior idle drain.
PS - PayPal was responsible for 18% battery loss and was apparently awake for 28 minutes, so maybe that's partially the culprit. I deleted it now and will test again tomorrow to see if the idle drain has changed at all.
All depends on use. What seems to hurt the Turbo is the display tech used. In spite of same chip, smaller display and bigger battery, the Turbo battery life per reviews is significantly less than the Note 4.
I haven't seen any info or direct comparison where the Note 4 is proving to have better battery performance than the Turbo. Where is your source?
I took mine off charger at 5am this morning 100% charged. Didn't touch it again until 10am and it was at 99%. That's special considering my house is a bad signal area, usually only -95db avg.
I wish I was getting this results
Decent battery life. I didn't really pick up my phone until 6 hours into the cycle.
We'll see if this 50% lasts as long as the first.
I'm still working on killing the battery from its first full charge. Currently 1 day 7hr 25m and @ 40% remaining. Ran a bunch of benchmark diagnostics today and have been streaming Amazon music through it most of the day. One thing I have yet to do is take the VZW/Android update, figuring I'd beat it up prior, then take the update and compare.
DannaOgle83
