Evo screen shots
I was wondering if you could tell me if there is a specific reason your running ATK? Not to flame or anything, just wondering. :-)
Sent from my PC36100 using Tapatalk
Is there any other way to kill apps i dont use??
The way Android is designed, you don't need to kill apps. They are supposed to "run" in the background. They run as a "snapshot" so the system can bring them back to you in the same state that you left them in. Actually after Froyo was released the task killer apps don't actually work anymore. If you do need to actually stop an application from running the proper way is going through your menu > settings > applications > manage applications > then select the app you want and press for force stop. Hope this helped. :-)
Here's a link to a great article on the subject.
http://androidspin.com/2010/05/25/why-you-dont-need-a-task-killer-app-with-android
i joined this forum. before i had a basic screen like when you buy a new phone and been reading and downloading alot of stuff and modifying alot and this is what i got so far still working on more stuff but just to not be shy
kolorado
