EVO update 3.70.651.1 pushing out now!
Restart and all your troubles shall be gone. I could use the internet after I updated but I restarted my phone and it works great now.
Sent From My HTC EVO 4G Using Tapatalk.
Keep getting "Installation Failed"
I did everything right, but when I am in recovery mode, the phone doesn't find the "update.zip" so I am getting an 'Installation failed". Where exactly does the update.zip file need to go?
I'm also having problems in using astro manager to rename it but I'm Having problems moving it to my sd card.
Downloaded the update, renamed it and copied it to my SD card. Went through the steps to install and got an error message
Installing update...
assert failed: file_getprop("/system/build.prop"
. "ro.build.finerprint") == "srpint/htc_supersoic/supersonic:2.2/FRF91/270276:user.release-keys" || [then three more lines of stuff]
This is what it keeps saying. Any thoughts?
E:Error in /sdcard/update.zip
(Status 7)
Installation aborted
Downloaded and went through the steps again and got the same error. My hardware is 0003.
(Status 7)
i'm pretty sure the manual update with hw 0003 was a no-go for every person that tried it here, best to just wait for the official ota update.. (i'm in the same boat, i feel your pain)
Can someone that has done the update please go to a streaming station using shoutcast and see if your stream sounds ok, or does it have pops and distortion? My problem started after the update, and I want to know if it is just me, or a problem with the update. Thanks.
Ok, let me rephrase. how do you enable it?? when I go to text someone, I just have the regular qwerty keyboard.
ooo lol.. i haven't received the update yet but i was using the swype beta up until today (deleted so there's no conflict during the new ota update).. but to enable swype i had to:
from homescreen, click menu
settings
language & keyboard
and i think it was there that there was a checkbox next to "swype". check that, then when inside a text field long press and select input method, swype.
as far as i remember that should do the trick, good luck ;)
The rooted OTA is out and will not break your root. Also if you use unrevoked it will change hboot to keep root forever.
If I use the rooted version of this update will that erase all of my settings? Sorry if this is a dumb question.
I also have HW 0003 and there is no OTA update. When I downloaded/copied/tried the 58MB zip, I also got the verification error and it wouldn't install it. I am guessing it is not the right firmware for version 0003.
Guess I have to just wait :(
Question:
My phone never received the 3.29 update a couple of months ago. It wouldn't play nicely with the manually update of 3.29 either.
Did anyone else have this problem? And does anyone know if it's a problem to go from 3.26 to 3.70?
Hardware version 0002. I haven't received the notice for the OTA, by looking through the forum it doesn't seem like anyone with 0002 has either.
Ttodd
