First leak for the specs from South Korea
I'm hoping they keep the screen size the same. I really miss the size of my v10 and note 4 now that I'm on the s7 edge. I've never used wireless charging so I personally don't care about that either. It's a safe bet that the v20 will also carry a high powered dac like the v10, but front facing speakers would be nice as well. That would be one reason to shrink the screen on the v20.
I'm also really hoping they keep the removable battery. It seems they cleaned house in their mobile division after the g5, so I'm really hoping they didn't bring in a new team that says "Samsung and Apple use sealed batteries and they sell like hot cakes so we should too."
They wouldn't have enough time after cleaning house to introduce significant changes.
This could be the final nail in the coffin for their almost premium status. Why put a 1080p display? Especially a company with their own display tech. Seems a bad move.
Makes no sense, so perhaps fake?
Well it's not like these are confirmed specs. Plus I don't see LG taking a step backwards in screen resolution. Also the V10 debuted with a minimum of 4gb RAM and 64gb of internal storage so I don't see the need for a second variant unless it's one of those country limited types. I don't think LG is as delusional as say Sony.
I would prefer a 5.7" phone but wouldn't be upset if its 5.5" as long as they don't drop the resolution. On the V10 you had the 2nd screen at the top which made the phone almost have a 6" screen. Maybe they felt like that made for too large of a phone and decided to go with a 5.5" + a 2nd screen? But I'm with you, after owning the S7 Edge for about 4 months now I miss the size of the V10....I also miss having a flat screen. The AMOLED display is nice but I miss the functionality of the V10.
What do you mean by the functionality of the screen? See, I might be leaving my Note 4 for the V20 depending on what the finish product look like, or it'll be the N7.
The 2nd screen on the V10 functioned almost like a taskbar. It made it super easy to switch between apps you used the most. I liked it better than the edge screen on the S7E.
These specs seem a little more believable
LG V20 specs leak again; 5.7-inch screen, SD-820, 4GB of RAM and Android 7.0
Yes! More leaks like this please. Now I just need to know that T-Mobile will get it, so's I can do the JUMP thing. Though unlocked would be good, too.
Only one camera on the back would be mistake. It really needs the 2 camera setup like the G5, with the wide angle on the back (or both sides actually).
I see talks about it having a 1080 but isnt that better on battery ?
pamatika
