[FIX][4-1-11]Latest ClockworkMod and SuperClean ROM's - Erasing the CWM Confusion
So you're back to DI01 then?
Heck, I'm already back to sc2.2.9 :)
Now I'm going to go hit the thanks button a whole bunch of times. :D
Serious shout outs to wyllic, DroidXCon, and all you others who helped me get through my first rooting drama.
LOVE this place!
followed the directions in the op and everything seems great so far! thanks to everyone that helped me. Glad that i did the extra work and went to stock eb01 first to clean things up, as im pretty sure i have messed some small things up in the past month or so. havent done anything in the new cwm other than flash SC so far though.
Well, my phone is all jacked up now. boo!
After all my phone drama today, I thought I was good to go. I finally booted up and was sc2.9.2 all over again.
Now I've got a black screen, non-working soft keys (though they light up), and the notification bar works. The unlock button doesn't unlock readily, but will if I keep trying.
Thoughts?
Golly, this totally stinks! boo... :'(
Thoughts?
OK, so let's start from the beginning to figure this out. What was your setup before you started on this journey? SC 2.9.2 voodoo or nonvoodoo? Any theme? Which kernel? Any other mods or patches?
Yay! You're here!
Okay, today I started with a beautiful non voodoo superfrankenclean 2.9.2
No theme.
Patch for the alarm clock (TW)
Today I went in to redo the fix by including to add the atlas pit file and check the repartition box.
Then began the drama. After several hours of only being able to boot in to cwm, I finally flashed DI01 through odin, then flashed cwm recover all then flashed 2.9 then 2.9.2
It was laggy, and the soft keys didn't really respond but I figured I'd work on it later. (after several hours because of dinner plans)
I think that's all. I was okay for a a bit, then restored my data and apps
Now after restoring I'm all black screens and weird stuff.
Help me, Lando!
I have a red triangle in my task bar with an exclamation point.
When I pull down the screen it says Unexpected error... please select this to help us fix the problem...
but I can't "select" it.
Yay! You're here!
No theme.
Help me, Lando!
How did you restore data and apps?
Have you tried rebooting?
My Backup Pro. Same as I've been using with no issues.
Rebooting after restoring my data/apps is what led to this
*yes, recognizing my high maintenance persona, sigh*
Yay! You're here!
No theme.
Help me, Lando!
Ok, this is what's confusing me. Why did you flash 2.9 then 2.92? No need for that. Do you know if you have any update.zip files anywhere on your sd card? I can't think of any reason you should have booted directly to cwm after putting the battery back in after doing the ODIN with the
Nevermind. I just reread your old posts and figured out your problem. You flashed DroidXcon's EB01 package in ODIN with the PIT file. You need to follow GizmoDroid's steps but use the EB01 file from SAHARAT'S post #9 toward the bottom of the first page of Gizmo's thead
Reactions: jampot
That is exactly what I did this afternoon.
I flashed the EB01 package in ODIN with the pit file.
oh. wait. not from post #9.
I wasn't planning on going back to the "fix" method. Just going back to the 2.9.2 from adry's link.
Does this make sense.
because she flashed DI01 and needed to use a wipe flash first...my guess is she didnt turn the phone on after flashing 2.9 and proceeded to flash 2.9.2 consecutivaly or however thats spelt...or the question of what options she used to restore is a good question
Bingo. I didn't turn my phone back on after flashing 2.9.
I immediately flashed 2.9.2. Bad?
*Isn't this how you learn?* ha. Sorry to take it out on y'all!
sukarisw12
