Flashing red border since JB update
I turned off all developer options and that seems to be working (so far). It was becoming more frequent throughout the day.
Yes I unchecked all the developer options and then re-started the cell Pantech burst p9070 & got rid off the red flashes.
Note: If the "strict mode" and "show screen update" it is uncheck, check them and then uncheck them.. ,and after that restart your phone.
For me worked , on an s2 model. ICS.
sony ericson anroid phone
a flashing red border appears in the background when i open applications
how do i get it to stop?
when i leave an application how do i get it to close completely when i leave it instead of running in the background , i think this may be the cause ? hellpppp
I have Nexus 5 and android 5.0 and whan I check something in developer settings then turn developer settings off and on it will uncheck everything and everything is unchecked but it stilll does this maybe I turned it on in 4.4.4 but now there isnt tha button :/
Turning off developer options worked for me. What and who are they for anyway? The phone even warns you that turning them on could interfere with your apps. Nuff said!
liquidsnake757
