Force the 4.3 OTA
Kept trying the trick as it worked for 4.2...finally got it!! Took too many tries to count...don't lose hope:-). Lol
sent from either Nexus 7 or DNA
Worked for me cleared Google services framework and immediately rebooted and the update came up.
The immediate reboot seemed to be the key.
Worked like a charm. Not sure if this helps, but on clearing the data there would be a popup about location services. Clicking on "Disagree" and then checking for update did the trick.
Yes!! That's exactly the tip I needed to make it work. Thanks!!
Worked first time for me on my nexus 4 in the UK. Updating now :-)
Tried multiple times but it never worked for me. I'll continue waiting. I heard they're rolling out by serial number and mine is pretty new since it was a replacement for one my wife broke.
Sent from my SCH-I535 using AC Forums mobile app
Thanks so much! I was wondering if the OTA had it's separate release date since it's been a while since they announced it. Wasnt too anxious though, its not my primary OS. Got it solved.
Thanks!!! I've been waiting for this update for days! I tried your original post and it didn't work. Clicked update at least 20 times... after reading others comments I restarted and tried the whole process again, then it after 3 times clicking the update button it worked! I almost gave up too!!! :-P Can't wait to try it out.
Buka Blokir BRImobile
