Froyo ETA Set
K sooooooo I think I know the answer, but its not a good one. Koush had said in his intro to the bootstrapper that if logwrapper gets messed up- you're hosed. Part of my error does say the assert check for the logwrapper failed. I'm downloading the sbf right now.
is everyone that is getting the error have a custom recovery installed?
it seems like that might be the problem...
Yeahhhh, I'm gonna wait on this. Someone wanna post a video showing Flash in action? :)
Anyone that was hoping for louder ringtones - it's loud as hell.
Thats great news Cory! Was your X dead stock when you did the upgrade - or had it been rooted previously?
Did you install the update directly to your phone - or from your PC first?
I want to minimize my chances of a brick.
I did not install Koush's anything. That must explain why it's working with me. I would flash the original SBF if you can find it.
Rooted. Made sure I put all the bloatware back to the way it was. Install is from SD card, not computer.
Ok, I'm done. Surprisingly, I only had to press "Ok" once during the whole process and that was to initiate the update. I was staring at the "red eye" for a looooong time (a couple of minutes). I started to get panic'y.
Things look different but other than that everything seems to be working. I still have SU so all is good.
Time to dig.
Thats great news for me. Still waiting a bit longer before i take the plunge. The update.zip file just goes on the SD card right? not in a folder on the the SD card just ON the Sd card?
Can anyone that has NOT rooted chime in if they've done the upgrade and report the results? My X is still unrooted and I'm leary of screwing the pooch with this upgrade.
Same here i was never rooted so im kinda worried.
Ok... so the story gets worse... sbf doesn't work... It gives me an error... cannot oppen recovery cache!!!! I'm hosed!!!!
Sorry for all the questions. Im sure you understand though. I dont want to miss some small stupid detail
Mine's loading up now. I'm going on less than 3 hours of sleep so we'll see if I can even stay awake through loading.
hiredbyskill
