Froyo ETA Set
Dumb question time. To boot into recovery and install the upgrade....
Do I turn my phone off entirely - then hold Home and press Power?
Or do I leave my phone on and do the hold Home/press Power sequence?
Turn off the phone.
Once off hold the home button
Power on your phone.
Continue holding home until u see the triangle
Then press search.
Use the volume down to select install update from SD
then press menu to select ok.
Cory would you mind doing a quick write up on doing this and keeping root.
easiest way is with root explorer (in the market)
what you are basically doing is moving the su file from /system/bin to /system/xbin
so with root explorer, go to /system/bin
longpress on su, select move
navigate to /system/xbin
paste.
presto!
Hmmm, I was rooted when I applied the update but now I'm not? What methods have you guys used to root post update?
This rocks, my write had me test flash on her site hopeparr.com and music and all works perfect. Wifi seems to be working better now also
I fixed my problem with the error 7 logwrapper thing.
It has to do with Koush's recovery.
What he did was replace logwrapper with a symlink to his hijack file but he moved the original to logwrapper.bin
I went into /system/bin renamed logwrapper to logwrapper.bak and then renamed logwrapper.bin to logwrapper.
After that the error went away and it let me patch.
No SBF use required. :)
that would have saved me some time! oh well, all seems well after the sbf.
I'm getting error 7 with system/framework/framework-res.apk
I replaced with stock theme though...
did you try theme remover?
[Release] Universal Theme Remover (Return to Stock) - Droid X Releases - AllDroid Public Board - [Release] Universal Theme Remover (Return to Stock) - Droid X Releases - AllDroid Public Board - AllDroid.org > Home
i think if you didn't move su to xbin and updated, you have to wait for a root for froyo
Something new: You can now rotate into Landscape mode in either direction :)
Turn off the phone.
Then press search.
Strange that it is that easy. The guys over on MDW have a very complicated list of steps to do this.
I'm currently rooted but I am thinking of unrooting to install this update. Also, let's say I install this update but want to go back to stock 2.1...how do I do that?
1397 on Quandrant!!!!!
Also calls seem nice and clear as usual.
Music and Ringtones are louder.
I like frame around the contacts pictures.
Seems greatly improved
Launcher Pro(free) is working fine for me.
And damn I didn't move the SU to Xbin... guess I am stuck waiting for Froyo root.
Oh edit guys maybe make sure it is installed to phone not sd cardsame with widgets I had that problem with my droid at first
tekpilat
