Froyo leaked for the Incredible
can we install this directly over a hydra kernel? I assume this will replace it, but I just want to make sure that it won't mess it up.
I guess thats what was in the first OTA update leak that I didnt have installed first but the only one that I have seen in the forums has had warnings about it so I didnt think it was a good idea to install
Everything on XDA leads me to believe that the leaked OTA radio update is necessary before installing the froyo. The Camcorder is a big fail point w/o it.
Wow...looking through all of the steps I may just wait until we get the official OTA. Unless someone can say this is extremely easy.
just drop it in the sd card folder. It doesn't need to be in a sub folder inside the sd card.
Man, and I was THIS close to getting under the covers and getting a good night's sleep for once :)
updating my radio now, wont be long :)
Murry; rename the Dinc ota.zip to update.zip. Remember to take the PB31IMG.zip off of your sd card.
Move the dincota.zip(should be renamed to update.zip) to the root of your sd card.
power down phone.
hold volume down and power button.
click volume down to recovery and click the power button.
now you hit volume up and power button.
select apply update.zip
I'm about to dive in, as well. Here's hoping we don't get screwed as far as the radio goes, cause if we do, potentially buh-bye future updates.
But who knows, maybe this is the final version and it will all go live tomorrow.
marik999
