Froyo RUU News, Reviews, Findings, Q&A.
Android Central showed some new widgets like News, and upgrades to the current ones.
& how did you get the update, OTA or what?
That may be true. The only widgets that I personally use are the Calender and weather ones. That is all.
I downloaded and installed it. The OTA has not rolled out yet, but I can verify that the file that was posted on this forum IS the exact same update that you will be getting OTA.
Ummmm... and how is that?
The build number's are the same. As I already mentioned, I am a Verizon Software Tech for RIM and Android. I already verified it. Yes, it IS the official version that has COMPLETED testing and is ready for release.
if you didnt get it OTA, then why is your thread titled "Official Froyo OTA, Review and Findings... "?????
LAME
And I'm the African Prince of Djibouti. Give me 500$ and in return I will gladly send you 1,000,000$.
Are posts like this common. I give some good info and insight, and then get called a fraud? I'm sorry if I offended everyone!
Because it is the SAME EXACT BUILD that's getting released OTA.
What a valuable contribution sir.
Last I left the office, it starts rolling out midnight TOMORROW...
I don't think your getting it. Your title needs to change. Your update was nothing more then the leaked version. You claim to have the "OFFICIAL OTA UPDATE" .... which you clearly do not. I would recommend changing your title and you might find that some people will back off.
This is the official OTA update. It has the SAME build number.
Thank you to OP for putting up the information. You're risking your job, unless this is all part of VZW's plan for global domination...I'm just kidding! Just trying to lighten up this thread. Cheers!
backup assistant only does your contacts, go to market and try mybackup pro. this will back up all apps and data
Not really a risk. I am not posting in the office. Obviously my job is more important, otherwise I might have TRIED to save screen shots or something, but I'm not a gambler.
re: Froyo RUU Review, Findings, Q&A.
A few things I've noticed.
1. The Gmail app is old 2.2
2. The Flash that installs is an older version too
By this, there are newer versions of both available.
X
Sent from my Droid Incredible via Tapatalk
X
So are you recommending for users to not download this?
dhickman
