G3 Battery Life experience. Whats yours?
Will do, but is that a normal thing to have to do?
Not usually. Whenever I saw the Google Play services issue I would reboot my phone and it would usually solve it.
Sent from my T-Mobile Note 3 using AC Forums.
Slow Charging! Very Very Very Slow! Crazy Slow!
I am charging my LG G3 from 4AM at 14% Battery Life got up at 8:30AM battery is on 57%!
Could anybody explain me why it takes so loooooong to charge a stupid battery? In this time my LG G2 was charged already while on the LG G3 I am not even half charged!
Is there a problem?
Anybody has a batter or faster charger?
Please help
P.s. Yes! I am using the charger it came with the G3/G2 (same 1.8Amp Charger)
Is there a problem?
Please help
You have to have a hung/loose process running in the background that's burning the juice almost as fast as you can draw it. Reboot.
Is there a problem?
Please help
I had the same issue but I was using my old Samsung S3's charger. When I started using the one that came with the phone, it charges from almost dead to 100% in about 1 hour to 1 and a half. Don't use your old G2 charger (even if it is same amp) if you are and use the one that came with your G3.
Mine is very quick to charge. If it is charging that site check what's running in the background and restart phone.
Figured it out! The charger that comes with the phone is crap! 1.8Amp is garbage, I got into my car at 10:01 with 60% at 10:20 it was at 80% and that's a car charger on 2.4Amp charger! So I ordered now a 2.4Amp charger from Amazon!!!
Take a look
Inateck® 12W 5V/ 2.4A 1-Port Compact USB Wall Charger USB Portable ... http://www.amazon.com/dp/B00IP8IBYG...ag=hawk-future-20&ascsubtag=UUacUvbUpU3773529
I get the 4.5 to 5 hours screen time which was the same as my s5 except I get a better screen 3gb of ram and 32gb of storage plus SD support and fifty bucks cheaper. No brainer. I can see running this the entire year. Sammy got cheap on this iteration of the Galaxy and pulled an apple on what you get versus price.
Personal preference always prevails, but how is ip67, better camera, battery, screen, heart rate monitor and fingerprint scanner over the s4 "pulling an apple"?
Sent from my SAMSUNG-SM-G870A using Tapatalk
My sprint s3 lasts only an 30 mins-1 hour on normal usage. When I am not using it, it will last 2 hours. It sucks
We also can't forget, many users are just picking up this phone so they will be using it all the time. 5 hours of screen on time is pretty good considering it's a 1440p screen.
Take a look
Inateck® 12W 5V/ 2.4A 1-Port Compact USB Wall Charger USB Portable ... Amazon.com: Inateck® 12W 5V/ 2.4A 1-Port Compact USB Wall Charger USB Portable Charger All-In-One Travel Charger for iPhone, Kindle, iPad, iPod, Smartphones, 5V Tablets, Bluetooth Speakers and Other USB-Powered Devices: Electronics
No. You have either a defective charger or defective cable. If your car charger cable is removable please try it with the stock charger. This is a common problem that happens randomly with new phones and has nothing to do with amperage.
websitedesig101
