Galaxy Nexus Screenshots: Share Them Here!
Beautiful widgets was getting a bit stale, so I got a new clock widget, called One more clock.
I keep swapping wallpapers, but the layout remains the same. Maybe if I could get a wallpaper of an android with a MUSE t-shirt then it would combine the best of both;)
With everything we are able to do to our homescreens, is anyone else having trouble making up there mind as to how they want it to look?
Sent from one of the following: Galaxy Nexus, Bionic or Xoom using Tapatalk.
Yes! I change mine every couple of days!
Sent from my Galaxy Nexus using Xparent Pink Tapatalk
This is mine currently... how do you change the bottom dock icons to text?
Current set up, who knows how long it will last. :)
I freakin love this phone!
Here is mine...I don't know if anyone else..likes the control soft keys I installed....keeping it nexus colorway 100%
Sent from my Galaxy Nexus running cm9 using Tapatalk
I have trouble everyday! heheh ;-P
Click to view quoted image
You have to flash softkeys. There's a neat app called ZipThemer which helps you out. You essentially get the softkey zip, configure the ZipThemer app (it's straightforward, but essentially you use either (1) your rom's zip, or (2) your theme's zip) and then flash the resulting zip file (and there's even an undo file if you don't like it!
If you google Galaxy Nexus softkeys I'm sure you'll find LOADS of threads/info out there ;).
Reactions: jcamposwpg
osirisgothra
