Would doing that reinstall/ or fix the baseband being "unknown"? Or should I try to like reinstall the baseband?
GetRIL doesn't work for me either but with changing the ROM.
1. Open up Google Nexus Toolkit -> Select 7 (as GSM 4.1.2. Model) -> Then Select 6 (Flash Recovery)
2. Once Recovery is installed, shut off the device and then hold and press Power + Volume Up + Volume Down (this will take you to recovery mode)
3. Once you are in recovery, volume buttons act as moving up and down and power as select button. While there select, Wipe Data/Factory Reset and Wipe cache partition
4. Reboot system once done (hopefully this will clear up the space), and re-connect your device to computer
5. Download the 4.1.2 ROM and Google Apps (gapps) HERE
6. Copy the two files downloaded onto the device (do not extract)
7. Go back to recovery mode and select install zip from sdcard -> choose zip from sdcard -> select the 4.1.2 ROM zip and then Google Apps zip in the order
8. Go back to main menu and reboot the device normally
Um. Well I got to step 2 but then when i selected recovery mode in the fastboot menu and pushed power it restarts and just shows the dead robot for like 10 minutes until it autorestarts to normal.
lol this is so ridiculous im going to go out and buy a Jitterbug
Edit: Oh you said to hold power +volume up+volume down. But its only up. I got it now, seeing what happens.
Where do I place the zip files onto the storage in particular? When I go to recovery mode theres an option to apply update from USB drive and it only shows ". . . " and selecting that just returns it to the main recovery options.
the root of the device, no need to put it on a folder...and you are not applying update, you are installing the zip file you downloaded.
Recovery mode only displays 4 options I see. It has clear wipe data, and clear cache, and install from USB or install from DBP or whatever.
Hi,
I am in a same problem as you are and have been following your thread for quite a while. Its really heartening to know that you finally got your device working.
Could you please let me know the different RIL / Baseband versions you installed and the one that is working currently for you.
Thanks
