Galaxy S5: Why does it say check back for tight water seal when turn on or reboot?
Randall Lind
16
The back plate is snap on and I have it in a bodyglove shock suit case (going to try Otterbox defender Monday I want a belt clip) but, every time I turn it on or restart tells me check back shows me a picture how to put the back plate on. Is this just a normal Samsung warning?
I checked and the back plate is on tight as far as I can tell. So I just wonder why it tells me this at start up. Thanks.
Re: Why does it say check back for tight water seal when turn on or reboot?
Normal software warning. That's Samsung covering their ***. Not sure if there is a way to turn it off or not....
Thanks I thought it was like the warning when I unplug the charge to close the dust cover for USB.
After a few warnings, I got the option to select "don't show me this again." So eventually, you'll be able to dismiss the reminder
When I had the S4 Active a lot of people were ruining their phones because they were failing to check the seal. Missing one clip could case water to enter the phone. And the S4 Active did not have a reminder. My guess would be that because of user error, Samsung put that there to remind you to double check.
Ya even if it secure, it still gives the warning
Sent from my SM-G900P using Tapatalk
HENRYBOY
