Galaxy S6 : Post Pictures Of Your Home Screen(s)
Domo icon pack.
I had a layout like that when I first got mine. Google launcher. Same clock. Liked it but I'm addicted to Nova. Still my two favorites.
I like Nova also but I feel like it used more battery than Google Launcher. At least in my experience
Made some changes to my homescreen. New wallpaper, switched the way some of the apps work. Using Nova and utilizing the swipe function to open two apps using the same icon. No clock or weather widget still going for the cleanest homescreen possible. Plus have noticed that my battery life lasts much more without them and I don't really need them.
I was gonna use that wallpaper. I had almost the same layout. Like what you did. I keep it simple now too. Not sure of you saw mine. It's on this page.
Perhaps I missed it. So many pages to go back and search, it'll take a whole day. Lol! But I think simplicity is the best way to go, I like to keep things clean.
It's on this page. Here you go though. 1440p wallpaper. A simple self edited zooper clock widget. And Nova launcher pro with two different icon sets. A simple black and a simple white. I went through a ton before I settled on this. Also double tap is set to bring up app dialer so I can access any app, contact, message, setting in a second. Of you don't have app dialer get it. Indispensable.
Oh then I did see it. I downloaded a wallpaper similar to this one from Zedge except it was all gold. The layout looks nice. Actually I had a similar app to app dialer called app swap but I'm since I'm trying to squeeze out as much battery life as possible out of my S6 in one single charge I'm removed it since it was one of the culprit to why I wasn't getting optimal battery life. With my current setup I've been able to get over 18 hours and 20 hours of battery in one single charge quite nice. Zooper seemed to be one of the major culprit which is why I don't have a clock or weather widget.
Thanks. Yeah I'm getting about 16-18 hours battery and 5 1/2 -6 hours OST. Zooper hasn't been affecting my battery to much. Uses about .1 percent of my battery. And app dialer definitely doesn't affect my battery. Doesn't even show up on gsm. Maybe you should give it a shot. I keep location off though. Blu tooth too. And only have WiFi on if I'm using it. Which is rarely. If I used just Wi-Fi I'd definitely get 6 1/2 hours OST.
How can I get this? I love it.
Sent from my SM-G920V using Tapatalk
I keep location on all the time, and Bluetooth off when not in use. I guess if I'm not using GPS frequently I should probably just turn it off. But then again I do use the weather app and Google now so it is sort of required. I think zooper was an issue for me because of the way I was using it previously. But I think without the widget it looks cleaner. I think being able to access your app drawer from anywhere is good but I use drupe to access my contacts from any screen. It gives you the same function the s6 edge has but better.
What's the icon pack?
Congratulations on this piece of art!
What's the weather widget?
Sorry it took a while as I had to track it down through the thread a little since I'm not using a clock or weather widget anymore. But here it is the widget is from Glam the other app also includes some widgets that I've used in the past that are quite nice as well.
They are two separate apps.
Weather widget - Circle Weather ($1.49)
https://forums.androidcentral.com/e...gns.zwskin.circleweather&hl=en&token=PKLqZg7s
Clock is from Glam- Widgets for Zooper
https://forums.androidcentral.com/e...com.marchesk.zwskin.glam&hl=en&token=qXokF5q-
zolepco1
