[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Re: [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.3
Actually, I thought you were talking about the lock screen... so I just checked a number of times by opening the app... worked just fine:
When a significant update comes through I'll probably wipe completely and start over. Everything else is working well enough right now that I not going to let the weather app animations bug me.
Re: [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.4
1.0.4 was just released... even they are saying: "(In Progress, not finished)"... I will install it as soon as it finishes downloading.
Another update :p Have to wait until I get home to download, these updates can be hard to keep up with.
I just flashed 1.0.3 ten minutes ago.
1.0.4 recommends data wipe...so maybe I'll wait for a more significant change log before I update. Haven'thad any issues so far with .2 or .3
It says MUST WIPE... not must data wipe... I wiped cache and dalvik cache.
Reactions: mclarryjr
Love this rom but I wanted to know if there were a way to delete homescreens? I only need 5. Also is anybody else having problems with myverizon? I cant login
new update?? really im go with .3 unless new feathers come im good :cool:
I have not found any way of deleting any screens.... and I just started MyVerizon app... it worked just fine for me... and before someone asks I just checked the NFL Mobile app, which also worked just fine.
Everytime I try to login to my verizon it says temporarily out of service please try again later.
I'd recommend starting over from scratch... delete the BAMF folder from your SD card... make sure you double check the MD5 Sum code of the ROM zip file... and of course make a backup... then wipe data, cache, and dalvik cache... then install the ROM.
I come bearing gifts!
Settings patch for 1.0.4
No shortcutting this time
Bamf settings back under Settings
3D tilt option
CRT Anims on/off options.
It will be in the first post too.
http://www.multiupload.com/HZS2GA2S3H
Reactions: The_Engine
Ya know, this is my first running of BAMF roms and I have to say im very happy with the Rom in general, but im also very happy that Adrynalyne is really keeping up with it!!! Thank you for the hard work you are putting into making this the awesome rom that it is!
So how does the battery life compare to gingeritis? I really don't care about NFL mobile or my Verizon.
so what was the surprise feature on this rom?
also why is it that there is no weather clock widget animation when its night time for 3.0 roms ???
it worked fine on 1.8.6.
again awesome rom... i will send some dough soon!
go team bamf!
1.04 fixes the srs. Hmmmmm. Have to decide if that is worth the wipe. This is smooth as the hair on a frogs back so far.
I just rolled back to 1.0.3 backup... just an hour or so ago I noticed I saw "Beijing" as my city on Beautiful Widget's Weather... so I added the Sense clock/weather widget to the screen and wow, I'm in Beijing... then it strikes me that my time is off... no it's not a little off, it's a LOT off... I'm in Beijing's time zone, which is 13 hours difference... here is my screen shoot taken just after 7am CST - in Minneapolis, MN.
Panic... ok... made a backup... reloaded 1.0.3 backup... I'm back to a normal location on my weather and the correct timezone.
How was the General Tso Chicken? JK I was thinking about changing 1.0.4 but i'll stick with 1.0/3 for now. I really like this rom. Many props to the BAMF team.
elnilphamari
