Gear 2 Neo loses BT connection
nklv_aleksa
11
Hi
Im not sure is this Gear 2 Neo or Galaxy S3 problem, but once per day G2N disconnects and then automatically connects via BT to Galaxy S3. Its not a huge problem, maybe its not a problem at all, but does anyone else has the same...I read, at some other net forums, that it might be a bug after the last firmware update over Galaxy Gear (1) where this problem occurs more often. But what about Gear2?
Anyone?
You are not alone on this. I also have experienced the random disconnect twice a day, didn't have that problem when I got it on 4/11.
Sent from my SM-G900T using AC Forums mobile app
I can't say for certain the problem is caused by the update, since I don't remember when the update occurred. The issue seems to occur about 1.5 weeks ago, and the occurrence gets greater each day.
Perhaps someone else can share their own experience?
asnes
