Ghostek Cases
Anyone have any issues with the Proximity sensor at the top when using this case? When I am on a call the screen does not Shut off and when I put a call on speaker then take it off speaker the screen will go black and i will have to press the home button to get it back on. Also when i make a call the screen will go black right away when press the call button.
I have taken the case off and everything works fine again. Issue only happens when I am using this case.
Just checked mine, proximity is fine. Maybe take the front frame off and see if maybe that is shading the sensor, mine is super close.
Couple things. Headphone jack hole is not very big, some may have issues with this. The top ports are perfect dead on center, but not the bottom ones. They line up, just not as perfect as the top.
I don't use the fingerprint scanner, but I'm gonna doubt you can use it.
It is a little slippery, but the thickness makes it a wash compared to a naked Note. The screen protector is generic and does not cover the whole screen, kinda junk imo.
I do like the color a lot. Mat red is nice. All the buttons work well, spen is easy to get out, and best of all, the bottom hole is oblong to fit Verizon models. I like the kickstand, but am leary of how long it's going to last.
Last. I almost like this better without the front frame. It's noticeably thinner, and the edges of the screen are easier to swipe.
Last last, uploading pics from an ipad to the site sucks.
..Last. I almost like this better without the front frame. It's noticeably thinner, and the edges of the screen are easier to swipe...
So, if you were to remove the top frame -- how badly would it be unprotected?
If you were to lay the phone face down, would the screen touch the surface?
Also, how does it feel in your hand? My current case has that harder poly-carbonate shell on part of the case and it kinda cuts into the skin between my thumb and index finger and it can feel a little uncomfortable/sore after awhile.
It feels fine in hand, all the edges are rounded off, and feel fine. The only sharp part is cutout around the S-pen. It's not really sharp, more pointy than anything.
There is still a lip that keeps the screen off the table without the front frame, so plenty of protection there.
So far I am enjoying the case and I like the look. Fingerprint scanner works fine. I have problems with generic chargers fitting the charge USB port but the stock charger and other few work fine. The phone is a tad bulkier making one handed use a little more difficult, but that's without using any one handed features. I use Bluetooth so I have not have to plus in headphones but I tested it out and my beats headphones fit just fine. For $8 this is a great case. It's a little slippery though.
Hey Hey Hey!
I work for sprint and i was finding it hard to find a waterproof LG G3 case since Lifeproof doesn't make them.
The case overall is sturdy and sleek.
I did what the directions said and tested the case without the phone in it to make sure there were no leaks: Passed.
At first i had an issue with the proximity sensor but then i took the case on and off and the issue resolved itself. Case fit to the phone: Passed.
When people call me I can hear them perfectly, when the phone is on speaker it's even louder than my regular speaker! Sound: Passed
As for the mic, sometimes people can hear me but more often people are saying I sound muffled: microphone: FAILED
The kickstand in my opinion is a stupid idea. The design of it is flimsy. It holds up the phone and the overall functionality is good but after using it a total of 3 times the kickstand stopped clicking back into the case. It would randomly pop out if I could get it back in for a minute, moments after. I'm on my 5th day of using it and the kickstand has already broken: Kickstand: FAIL
The waterproof of the phone is awesome. The headphone jack piece fits in perfectly and working perfectly. The lines on the screen are a little disconcerting but doesn't effect the picture quality of the device. I've placed it in water a few times just testing it and I haven't seen a link since. Waterproof: Passed.
It is a great case and with the lifetime warranty i can get over the kickstand issue. As for the microphone issue I use the LG bluetooth headset so again it doesn't bother me. It's a good case, protective and waterproof I just don't like the kickstand.
MichaelCrusan
