Gingerbread coming to Incredible 2
I am worried that gb will kill the chance of getting s-off any time soon. The main reason I want to root is being able to do screen shots from the device. Bloat only bother me because it exists. Launcher pro lets me hide the shortcuts.
Sent from my ADR6350 using Tapatalk
I had no signal at home after activating DI2. I slipped on the shell case, and the signal strength came up to -95db. It's weak, but it works. The battery drains very quickly which I attribute to the weak signal. I will certainly post an update if this changes with OS upgrade.
I heard some people are getting the update. But I don't know if the source is real or not. Wait till the afternoon since this update is like 150MB or something.
How do you get the update, will you see it waiting for you if you click on "software" or is there something else you need to do?
Thanks
Bill
I've checked a few times and it says no update available for both of my DINC2s. I've looked online and I haven't seen where others are getting it either.
Oh well, maybe tomorrow.
Updates are usually pushed our regionally. If you are not getting it now you should later in the day.
If you've listened to a few AC podcasts, then you should know it doesn't roll out by geographical region....
I think it's done alphabetically and by height. :D
But seriously, has the date of the update been formally confirmed? You know how we in the Android community thrive on rumor and tiny bits of information.
martin45
