Gingerbread NOW available
I want GB on my X but i have no clue what or how? I can follow directions if someone could tell me how to get it.? Feel free to email me instructions at moongrlxx @aol.com. thanks im so excited to get it!!!!!
YouTube - Install Gingerbread 2.3.3 Leak WITH ROOT on Droid X DroidX ! How to Flash Tutorial
This video helped me, but I was already rooted running Rubix.
In order to better help you (and I mean the experts not me) they need to know what you are currently running on your X.
You are in the minority on this. Love GB, very fast and responsive, a few little bugs, but to be expected with a leaked version.
Ill go just a little more w/ this and say it's been flawless after syncing w/ google.
Sent from my DROIDX using Tapatalk
maybe you could try reading. There are multiple threads/posts with instructions (or links to instructions) on exactly how to do any and everything having to do with rooting and/or this gingerbread leak. They aren't hard to find either.
ps- i know i sounded like a jerk, but i mean....come on people, just read a little. This stuff isn't hard to find...at all. :D
Reactions: jerseyboy357
I just tried Quick Clock on this and it's working! Fyi. :-)
Gingerbread is NOW THemed!!!
You have to be Deodexed for the theme, link provided in OP. I had no problems using DX bootstrap (minus a bootloop but a simple battery pull and Voila!) so go ahead and give that a shot first.
Alpha-1 Theme for Gingerbread
http://www.mydroidworld.com/forums/...e-alpha-1-stock-gingerbread-dx.html#post64214
I have not done anything to my dx it's untouched.
Rare to hear that these days, especially with us all goin nuts with the GB stuff,lol. Whatever floats your boat will make a happy phone user.
Thats awesome now that theres a working theme. As soon as I figure out why I cant get CWM or Bootstrap to get into recovery so I can back my stuff up, I will definately install that theme. Its sitting on my pc waiting to go onto my phone :-!
Deodexed and themed w/ Ginger.. :):):)
I'm sure you probably know already but just in case...have to use Droid 2 Bootstrapper. There's a free link posted over at the mydroidworld forums :)
I had success using the DX Bootstrap, do a backup though no matter which one u use. ;)
You don't have to use Droid 2 Bootstrapper. If you want to use Droid X Bootstrapper, you can, so long as you turn off USB Debugging.
By the way I got cwm recovery to work. I disable USB debugging and bootstrap works fine now. Gona try ROM manager next just to see if it will go into recovery now that debugging is disabled.
hmmm thinking about trying now since its Deodexed. Might be forever for the official GB to get released .
Once there is an custom rom for GB out no doubt I will. Getting closer to pulling the trigger anyhoo :D
ok now i need help i followed all directions and rooted but i cant seem to get the gb to install frm sd card. every time i download it to card then go to install it says "no files found" HELP PLZ
It must be on the root of your SD card, meaning not in a folder of any kind. Open up your SD card and drop it onto there by itself. Then in recovery you should see it as (whatever its named).zip chose that to install.
east and west are reversed in google maps, sky map, and earth. Gps locks very quickly but no longer displays the margin of error. Browser is laggy upon reopening because the pages have to reload. Overall the system is way faster than stock, but liberty with an overclock is completely lag free. I'll give gb another try once it's rooted, but for now, back to liberty.
I'm noticing this issue as well. East and West are reversed but not north and south. The compass works just fine, though.
Has anybody else seen this bug? Is there a fix yet?
Also, I have not had the opportunity to test Google Nav yet. Will give it a go on the way home today and see if the problem replicates there too. This could be a deal breaker for me.
MWavy06
