Gingeritis 3D v1.2 found in the wild
Does restoring system settings and home screen using mybackup pro the same as system data?
Don't know... never used it... never will use it.
Do you think I should upgrade to the new radio? And how do I do that without breaking root with revo?
If you are not having any issues, then I'd say no... but if you want to, then do it. If you do update your Radio you should follow the directions I posted above, go to the link and check Post #3.
any fix on problems with saving new contacts to my contacts list as it doesn't show up, my verizon and nfl network not signing in, netflix streaming choppy even with wifi...
does this ROM have the same problems with the stock email client and Yahoo where the mail message suddenly disappears soon after reading an email?
My Dibble Dibble
So I;ve had this issue with v1.1 & v1.2. ROM seems like its hangs for a split second whenever I execute something like opening the keyboard, typing, opening the app drawer, settings, etc. Is anyone experiencing this and is there something in my phone that could be bogging down the processor?
I want this ROM to work but my phone keeps restarting, I've seen others have this problem but not a link to the answer to stop this. Can somebody please post a link. Thank you in advance.
Did you flash a new kernel? You need the 9-13 Ziggy kernel yo avoid reboots. It is included in the rom.
Sent from my Thunderbolt via Tapatalk.
No, I have the 9-13 that came with it. Should I re-install the ROM again or just flash the ziggy 9-13 kernel?
This was my first ROM that I installed and I am loving it. Thanks AC users and members for all the info in these forums...made it easy for a newb like me.
Sent from my ADR6400L using Tapatalk
So I re-flash this ROM and everything is good. I load applications from the market instead of from my backup to see if any individual program is causing my reboots. All good until I install Juice Defender battery saver and I get my first reboot within half an hour, I had juice Defender Ultimate already downloaded but it needs a basic Juice Defender program to work. So my question is,is there a setting that I need to change in J.D. or does it just conflict with Gingeritis?
When I install Dock Mode with this ROM and attempt to start it (either manually, or by putting it in my HTC dock), it forces a device restart every time. Any idea why? Is there a working Dock Mode apk for this ROM?
My Dibble Dibble
I've had this happen quite often on my unrooted Thunderbolt, running both the 2.11.605.5 and .9 versions.
I've also updated the Yahoo! app multiple times with no success. My wife has never had a problem with her Incredible2 and Yahoo! app...
So my guess is this is a Yahoo!-based conflict with the thunderbolt or some other random app we might have (although I had very few apps on my T-Bolt). I chalked this up to "Yahoo! sucks," since I've had issues with their web-based browsers sucking ass also.
So yeah, Yahoo! sucks.
I've been running G3D v1.2 for a couple months now without any issues until just the a couple days ago.
Phone randomly restarts. I can't find a particular app or keystroke that causes it. I've used the phone normally, nothing has changed. Downloaded a few apps here or there. Tried uninstalling the last few apps to see if that was the problem, and it still restarts.
It was mentioned in some posts above to try installing the ziggy 9-13 kernel, but I thought the Ziggy kernel already came with the ROM?
Any suggestions?
uOttawaGrad_22
