Go SMS pro no contact photos after ICS
Im about to start throwing stuff. I rebooted my phone and got prompted to sign back into face book. So I did. Then it told me it needed to sync. So I did. While I was doing that I checked and the pictures were showing up in Handcent. Then apparently after the FB sync completed all of the pics were deleted. Arrgghhhh
I'm telling ya, dudeski. Try Facebook Contact Sync (free), or HaxSync ($.99).
In order to get FCS to work for Go SMS, I had to delete the facebook account out of "Accounts and sync" in the settings. Once you've cleared your facebook info, FCS takes over as default for contact pictures. You can make it so it uses higher resolution images, and it's really good at finding faces in facebook profile pics.
HaxSync works 100% for Rezound. Follow the instructions on the app's page.
I did and it didnt.
So maybe that is the problem. Only one can sync with the contacts?
Phuckwithfire is correct, here's the steps that worked for me.
1. Delete Facebook from Accounts and Sync
2. Install Facebook Contact Sync
3. Sync Facebook Contact Sync
4. Wait until it completes (can take a long time)
5. Open Facebook, it will prompt you for what you want to sync. Select don't sync.
6. Win!
I'll certainly try out that contact sync app, but yes I have the same problem with handcent and with circlelauncher using the contact widget, glad to know it's not just me
Well I tried Facebook Contact Sync and it seems that the only way for it to work is to individually link each google contact to it. I really only want my existing contacts linked to their profile pictures from Facebook but I haven't been able to figure out how to do that yet. Anyone know if you can linking existing google contacts to their Facebook profiles via web?
I'm having a new problem now. Friend Caster works fine. Now I'm not getting delivery reports. I was last night, but not now. Everything is checked properly, and it's set toy default for sending / receiving. All of a sudden I'm not getting reports.
Sent from my DROID RAZR using Android Central Forums
And now all of the synced contact photos have disappeared. Interesting thing is that even though I had fb set up to not sync it decided to anyway.
Sent from my ADR6425LVW using Android Central Forums
I had the exact same problem...I posted this earlier, maybe you didn't see it..
6. Win!
Reactions: Jazzy79
I did follow that. The problem I am running into is when I go to use the FB app again. I log in,, chose to cancel when prompted for background sync and told it not to sync. Yet it still its. Pretty danged vexing.
Well I uninstalled Haxsync and lets see how this goes with Facebook Contacts. Interesting thing is that I removed FB from sync and accounts, installed, and started FB Contacts. I logged in and started to sign in. FB came right up and started to sync on its own (WTH). So I stopped it and turned off syncing and and now running the FB Contacts Sync app. Let's see is that works.
I also had this problem but I already found out how to see the contact images in your message box using go sms pro.
Here's how:
1. go to your contacts
2. look for "Display Options"
3. Find "Select contacts to display"
4. touch the dropdown button of "SIM" then check the "All contacs" box
go back to contacts again and see all of your contacts does have images on if have copies on your sim ( contacts with green sim icon)
now it's your choice if you want to see your contacts images on, on your Go Sms Pro
because you'll be needing to delete the copies of your contacts on your sim cards for you to see their images..
Well for me it's easy to copy all your contacts from your SIM card to your phone and viceversa if you'll be needing to insert it to another cellphone, right?
Things To Remember:
There shouldn't have any copies of your contacts phone no. on your SIM it must be only saved to your phone memory.. Anyways you will not be able to save images on your contacts phone number/s if it's only save on your sim.. I hope anyone here with the same issues find this article helpful.. ?
Can I ask what email address you used. I've been trying to contact them for a week, and have had no luck. Please let me know
Maxyguy666
