Google Maps update reboots phone
One option is to go here in your mobile browser:
Google Maps 6.9.2 - APKTOP
Download & install.
I installed it ... no reboots.
I made sure to uncheck auto-updates for Google Maps in the Play store, too. Currently waiting for version 6.10.1 or greater.
TBolt ... I was waiting for you to do it and so I just did it! I am back to 6.9.2, which is better than 6.3.
Thank you!!
I just went into manage apps > all apps > maps > uninstall updates. No need to find another version, right? (And yeah, be sure to deselect automatically install updates.)
Thank you!!
No need to thank me ... medic673 installed it before I did & reported it was okay. Leave it to a medic/fire guy to be the brave one. lol. Thanks, medic!
Reactions: medic673
Thank you, Medic!! I appreciate your bravery!! :cool:
Thanks everyone! These forums are awesome! I have been having the same problem with my navigation and it was driving me insane. Then I looked here and "bam" found the answer I was looking for. This will be the first place I go for now on whenever I have an issue with my Rezound. Thanks again everyone for the help. :D
I was afraid it was an incompatibility between my custom rom on my sensation but am happy(?) to see it seems to be an overall htc - google issue. Hope it gets fixed soon but while I'm waiting I don't have a problem with the older version. The cache delete thing didn't solve the problem for me.
Link now says unavailable. Any ideas?
Also, this from the Google Products Forum...
cindych
Aug 17 (3 days ago)
Hi Everyone,
Thanks for your reports. I have escalated this to the product team for investigation. I may reach out for more details if necessary. I'll provide an update as soon as I can.
Cindy
cindych
Aug 17 (3 days ago)
Hi Everyone,
Cindy
The iapktop link works. I just clicked on the 'download from apktop' link.
Sent from my ADR6425LVW using Tapatalk 2
Thanks for link now on 6.92. Works like a charm.
I don't get it...why are so many people downloading a link instead of just uninstalling updates?
We did uninstall updates; we were sent back to version 6.3 (or, 6.2 ... I dunno), which sucks.
So, we found a more recent version to use until Google fixes the bug.
Keep version 6.3 if you want. I didn't like it, personally.
Uninstall takes you back to the very basic version. There were a lot of cool updates since the. The apk works great
Sent from Chucks Rezound
Reactions: ShadowCatcher
We are uninstalling the update, which brings us back to version 6.2(the version that original came with the phone.) The latest, good version is 6.9.2. It has the "take a map with you on your phone" ability for using maps when you are off the cell phone grid. It also has rulers to measure how far it is from point a to point b, and shows changes of elevation along the way.
Version 6.9.2 has to be "Side Loaded" from a link on the web.
Version 6.10 is the bad version now available at the Play Store.
OK, I see I typed before seeing the question was already answered. Sorry!
Checking it out...the latest doesn't have the phone bubble lab feature. Anyone know what the 6.9.2 version has that the original doesn't?
DrKayak mentioned a few things above. You'd have to Google it for more details.
Google graduated the feature from labs, but now we get only one bubble instead of two. You set the bubble action in Settings > Display, I believe.
Gotta love Google breaking arguably one of the most important features of Android with this latest update. Downgraded back to a previous version as well til they fix this one. I do miss the spiffy new icon of the new version.
Today I needed to use the voice navagtion for the first time since the ICS update. It rebooted on me 4 times while in use. I wasn't very happy about this because it made me think something might be wrong with my Rezound.
I arrived at my destination early and gave Verizon a call. It is noted in their documents that there is an ISSUE in the Maps on ICS and it ISNT our PHONE...........yay on that.
No need to fret.....said to uninstall the latest updates on Maps and that will take care of it.
I uninstalled the update. I knew how to get home but for the heck of it, I ran the navagation and sure enough, it was perfect.
So dear Rezound friends, it is in the MAPS. Keep it at stock till there is a fix on it and you will be good to go.
Judi:):)
Cheezy313Bby
