Google Nexus 6P Must have apps
i was a nova launcher fanatic till i tried the microsoft arrow launcher. so far so good to the point that i have uninstalled nova.
Re: Must have apps
Light Flow is a good start... it will let you change the notification light to be specific to what you like... Blue for Gmail, Green for SMS, etc, etc.
I tried Light Flow and it didn't do anything. I have a brand new Nexus 6P and setting it up while I await a SIM card so I can activate it. I installed and after setting up the colors for notifications I clicked "Test" and nothing happened... no LED anything. Any ideas?
I think you need a custom kernel to open up the led for light flow to work
There are so many similarly named apps in the Google Play Store - this Light Flow https://forums.androidcentral.com/e...geconsulting.android.lightflow&token=dLKu2iLy is what I'm using on my 6P (currently running the N beta 4 build) and the LED is working correctly. I did have to make a couple of setting changes to get SMS working properly, but WhatsApp, Gmail and Missed Calls all worked right off the bat.
BTW, the Tools -> All enabled LEDs Test feature worked as expected. And I don't have a custom kernel or any other modifications.
Re: Must have apps
what? Nobody has mentioned Evernote yet?
This has become critical to my life and now cannot live without it. It all started on my phone, but I access the Web based interface from work too.
Evernote stabbed it's free and loyal users in the back...I'm sad I had to find a alternative
Thanks GSDer... I'll keep at it. Must be in the settings that I'm not seeing. I appreciate the response.
mitiku Berihe
