Google Nexus 7 Tips and Tricks
Okay so my Nexus 7 arrived and I love it, using a bunch of the tips posted on here!
One question, is there any way to play media from my Nexus 7 on my TV WITHOUT the use of an internet enabled TV or a Media device such as XBOX/ Playstation/ Wifi Bluray player?
Thanks!
Thanks!
I don't think so, but Jellybean 4.2 will support Miracast - Google that and see if you like the idea.
Great idea, but still developing. I believe Phil and JR Raphael's reviews mentioned that NetGear "Miracast" devices didn't work with the N4 4.2 (pre-release version) due to the the device being "pre-standard compliant." I look forward to seeing compatible Miracast devices and TVs being available in 2013 (crossed fingers). It could be a long wait though.
Made me laugh. Great post!
what a stupid forum that does not link replies to the original post.
It actually does. Just click on the original post and click quote. Or If u wanna quote more than one post click on multi. :)
Thanks for the answers all, one more thing, can you connect an external hard drive directly to a nexus 7 without connecting them both to a PC/ Mac?
I've been trying to find out the same thing. The Nexus Q will do it but that sucker is expensive.
You can easily stream music from the Nexus 7 with a cheap bluetooth adapter. Also if your TV is DLNA compatible you can stream media.
Thanks!
Found very little information online, about doing it with rooted devices, I really don't want to root my shiney new gadget, it would be great to find out if there are any other options.
-hint hint-
I think you can do this using an OTG cable. I haven't tried this yet myself though. However, you may run into an issue if the Nexus can't supply enough power to the external hard drive.
I've done this successfully using a powered external drive prior to the 4.2 update on my rooted stock Nexus 7 using StickMount. It looks like 4.2 broke StickMount, though.
Sent from my DROID4 using Tapatalk 2
I am not sure if this "tip" has been discussed already in this thread, but do not encrypt the data on your Nexus7 unless you are some type of paranoid spy.
When I encrypted by Nexus7 it was NOT buttery smooth at all and when I was doing simple things as typing, the table was not able to keep up. And if you want to turn off encryption you will need to factory reset and that I be a larger pain the butt than you think, (I forgot to back up my FinalFantasy gave file).
here is what i tried before stickmount stopped working with 4.2
wd500g portable hhd.
usb hub with 2 thumb drive attached. both can read and xfer files back and forth.
one thing to note is that the n7 do not support exfat formatted hhd.
Android 4.2 added new wallpaper and alarm clock ringtones.
Hey fudd
until they get stickmount up and running, Nexus Media Importer seems to be pretty good. Plus it works on unrooted systems.
hiredbyskill
