Google Wallet 1.1-R67-v4 (June 6th update)
Well tested out this new version today and it worked perfect .I do have the older on backup I keep of google wallet just in case tho ,I always have a backup plan ,,,, well most of the time anyhoo :)
Reinstalling wallet feels like a crap shoot.. but if you're not seeing secure element wait as long as it takes
Update: I decided to update wallet. This time I chose to remove card first, and after that finished I reset wallet normally. In order to be on the safe side I did not allow my phone to fall asleep while it was resetting. Then I uninstalled and side loaded normally.
This time the whole process of initializing didn't take more than a second and adding a card only took 3 or 4 minutes.
So times vary incredibly
I installed Wallet by the browser method months ago. It has been working fine. I even got some updates.
But now it doesn't show up in my apps unless I select the All. It does not show up with the market app as an installed app. It also does not show when I search the play store for the app.
I used it yesterday and it is working fine. But why doesn't it show up? Will I continue to get updates? Who knows?
Cuz its not supposed to on a VZW nex..
You won't from the market, most likely, but you'll be able to get them on the chat boards within the day of any update.
Most importantly.. I would advise that if you can still use whatever version you have without issue, don't bother trying to update here. If eventually it stops working you'll probably need to update.. But in light of the issues people are having updating I'd try to postpone it as long as you can if it still works as is. Just to avoid complications :)
Yep, that's how I am able to update. I also used the browser method way back when... this is why it shows up for us. That method no longer works, so we are the privileged ones who can update this way. Everyone else on vzw has to sideload an apk.
Don't question it, just embrace it ;) :D
*customized tapatalk signature*
Didn't know they fixed the loophole. Anyway I have to actually search for wallet, then the update will show up for me.
FYI > If any of you are on Sprint with the new EVO 4G LTE. It will not let you add the Google prepaid card. I called Money Network about this problem and they said it was not currently working and they did not have a date when it will be fixed. So much for using Google Wallet with a new phone. :(
Why would any of us be in that situation when this is the verizon galaxy nexus forum? Lol
Works great except for the "unsupported device" banner.
:cool:
Can't tell if serious or trolling.... but the fact that its the first post for an account over a year old actually leans me toward the latter.
EDIT: Oh that and the avatar... :)
devicedecode
