GPS / Batter Charging issue....
azhalvy13
9
6
Ok, so I used my GPS today, in the car dock connected with the car charger. Drove about 130 miles using the GPS navigation. Started off with the battery charged at 70%...by the time I got home the battery was at 60%..The charger was connected the entire time and you could see the lighting bolt in the battery icon....
Basically, the phone used more juice with GPS navigation than the charger could put back. Ive done the with my OG droid, Droid 2 global and iPhone, never had that happen.
Could I have a bad device? The battery seems to drain with normal use...Another example, when to dinner tonight and in 1 1/2 hours of very very little use battery dropped from 60% to 40%..
Some car chargers have a higher output than others.
You need one which puts out at least 1amp for it to keep up with the Razr.
Mine puts out 2 amps and charges my Bionic nicely.
Sent from my DROID BIONIC using Tapatalk
Avanish09
