[GUIDE][8/1] Jelly Bean Now! Resources & Discussion
Sent from my Galaxy Nexus running Jelly Bean.... Whud UP!
Updated lol
Sent from Oliver, Lord of Time and Space and All Things Gelatinous
I to have been having good luck with 2.5. And just think where running hacked together builds I cant wait to see what they run like when we have proper code.
Sent from my Jellybean powered Galaxy Nexus
Re: [GUIDE][7/6] Jelly Bean Now! Resources & Discussion
I dirtied too.
Stick to clearing system, cache, dalvik, and 9 times out of 10 you should be fine with the update.
so does the clearing system mean wipe data/factory reset? I only see cache, and under advanced is dalvik.
as for the gapps /74 proper, do I really need to re-flash them since there's no change or is it good practice to just re-flash also.
I did a DF without data/factory reset yesterday but don't want to play with fire on a JB port.
:D
Thanks,
Xanth
Quick question guys can I flash the circle battery and power menu Mods like I flash the ROM?
:D
Thanks,
Xanth
Always flash gapps wiping system just deletes the rom it won't touch apps or settings. A factory reset wipes the rom and all the user data.
Yes just make sure its jellybean ready. Some of them are some are not.
Reactions: DB12088
so just wipe cache and dalvik flash ROM and gapps than reboot.
I am assuming the are jellybean ready they are the ones from RW in the jelly belly thread is there another way to make sure?
Edit: can I flash both and simply reboot?
If there in the jb thread your. all set. I just would not be flashing ics mods without checking first
Reactions: DB12088
Thanks Yoda, I really appreciate all the great advice
I wipe cache dalvik and system (mounts and storage format system). Then flash rom and gapps
Got battery on charge will do tomorrow if easy day but my luck 2.6 will be out before I get the chance to flash 2.5 lol
Anyone have a mirror download for 2.5 ? Too many on the first lol
Look up System6 in the RW thread. He posts mirrors relentlessly lol
Any one try our the new razor jelly 2.6. How does it compare to jelly belly. ?
stopwatch
