[GUIDE][8/1] Jelly Bean Now! Resources & Discussion
Re: [GUIDE][7/12] Jelly Bean Now! Resources & Discussion
Ah, I didn't realize he had color settings, too. I'll hunt around for an app. Danke
Bitte!
Full Disclosure: it takes a day or so to get used to and looks a bit blue at first. I can't live without it now though lol
Just be aware you have to go get the offline speech pack (language of your choice) in Google Now => Settings => Voice. Then Now works like a charm :).
I checked this on my phone and it was already installed. One of the first things I check is navigation to make sure there is speech each time I flash something I live by the Nav on the phone some days.
I believe that Jake has it pre installed. I could be wrong though lol.
If you're on Belly, be sure to check out that lib fix.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
I'm on 3.1 so I have the 7/11 Gapps. If dirty flashing to 3.3 do I need to flash Gapps again anyway?
lol... what in NYC can possibly require NAV?
south of houston where the streets get all wacky? just a guess.
i used to drive trucks occasionally for work in manhattan/brooklyn, to pick up or deliver art works etc. which is btw one of the worst things you can ever subject yourself to. driving a truck in manhattan, that is.
i used to drive trucks occasionally for work in manhattan/brooklyn, to pick up or deliver art works etc. which is btw one of the worst things you can ever subject yourself to. driving in manhattan, that is.
fixed it for ya :p
driving w/o GPS below houston street is an ART!!!
totally off subject but anyone ever take a truck in a freight elevator to the tenth floor of a building in manhattan? it feels exceptionally odd. and you would think a truck elevator would be bigger than they usually are .. .
Well lest see , just because my tag is NYC my job requires traveling to Westchester, Putnam, Orange, Rockland, and this weekend I am off to the Lake George area to drop my son off at a sleep away camp with the BSA.
You's also be surprised how many little streets there are in da Bronx off a secondary street.
Xanth-
Been in a very large freight elevator for a plumbing warehouse that was able to put in 3 hi-lo's
Ok, I guess I'm ready to take the plunge. Should I go Bugless Beast, or Jelly Belly? Thoughts?
Thank you, got the file and put in the lib folder, works great.
How come you can not gain access to the file structure in windows explorer? I can see everything on the SD card. is there a setting for this? I had to use rom manger to fine the file and move it that way. is the file structure hidden in explorer?
Xanth
I can only speak for Jakedays JB, I have 3.2 and so far no issue, stock kernel for now, maps, nav, and what ever else I have running have no issue, no force closes, etc. although like anything else it becomes the end users choice, like when we all had choices of AOKP, Gummy, Liquid and so on, we all migrated to what we liked and got use too.
Best of luck, there is a great team of AC advisers and mods to guide you in your quest.
Xanth
Reactions: EJT
I might wait until 3.4 drops a little later and flash that. Dunno yet. Just did a nandroid and backed up all of my SD card stuff, so I'm good to go.
I would just flash 3.3 and then dirtly flash 3.4 if you want. I just dirty flashed from 3.1 to 3.3 and all is great.
jr212
