[GUIDE][8/1] Jelly Bean Now! Resources & Discussion
Weird; what GAPPs did you use? Gallery2 is still in the ROM's zip...
I have only 1 gallery. Using Kejar's latest gapps. I dirty flashed from 7/16 and almost all is fine. So far, the only issue is when I go into the Franco Kernel app, it continuously asks for root permission. I don't really need the app right now since I'm using the stock kernel, but it's odd. Wasn't happening with 7/16.
Someone with Kejars latest gapps, can you link me?
Re: [GUIDE][7/12] Jelly Bean Now! Resources & Discussion
Weird. Kejar's has GoogleGallery and the rom has Gallery 2, so you should have 2 Galleries (or at least two gallery apps in your system/app). Very weird.
Thanks though! :)
Thanks though! :)
Just checked system/app. Only GoogleGallery in there. Can't explain.
BTW, new CM10 Kang build out. SU binary no longer needed. I'll let you know if you still need to delete Gallery2.apk.
I was having issues with apps continually requesting root permission. I saw on XDA others were having that issue. If you're having the issue, the fix is to reflash the su binary despite it apparently being in the latest rom.
Nope, no issue there. I did go to the SU app and update the binary though. For some reason the included one read 3.2; the flash one is 3.1.3. I updated it, it went to 3.1.1 I believe and all's fine.
I tried updating the binaries before re flashing them. That didn't work for me.
Any thoughts on starting a dedicated CM10 Nightlies thread?
Perhaps, it wouldn't hurt.
Be my guest :p
Also, just replicated that asking permissions thing. It's definitely the binary. Tapped it, updated fine, now it's all good. Beats having to flash the thing over :).
Reactions: msaly
so can i use JB 7/14 gapps, or do i need to look for kejar's 7/15 for CM10?
grabbed it from the earlier link by msaly
well, here goes nothing...cm10 here i come
is there ANY benefit in unrooting/relocking the phone, and starting from scratch, sort of the "freshen" it up?
I've done it. Clears everything out.
i was hoping you'd say no :p i guess this will be good practice with ADB/Fastboot
i think i will do that when AOKP drops
Reactions: 7stringer
Nammna
