[GUIDE][8/1] Jelly Bean Now! Resources & Discussion
Re: [GUIDE][7/12] Jelly Bean Now! Resources & Discussion
Always depends.. Even a nightly can change just enough that dirty gives you problems. All depends on what exactly changes in the system.
see... this is why you have that nifty orange tag under your avatar :p
got a few minutes and flashed CM10.... 10 min in and no boot up yet :-/ going to give it a few more then recover back to Xenon if it fails
edit: pulled batt, re-wiped and re-flashed. worked this time. i can see what all the fuss was about CM10.... digging it so far.
CM10 is in good manager. It looks like build 18 is in there ready to goo.
Edit: oops, that would be cm9 I guess...
I typically run fix permissions after I've installed everything (under advanced in CWM), which can also help prevent some app issues.
Fix permissions shouldn't have to be run, since like early gingerbread days really. I know I've seen a JB ROM or 2 say to do it but honestly that makes me lose faith in the dev if they are asking for it, and I'd rather not see people get in the habit of thinking they need to do that.
Quick question guys would it be better to start using TWRP for backups due to the issues being reported with the updated version of CWM
No disrespect to Koush, but I think that TWRP is just a better recovery regardless.
latest cm10 is up... git it!
dm, you try it yet, especially with the new gapps? did they merge the goodies?
Reactions: 2defmouze
Flashing in 2 mins once done, will report back.
Status bar appears to work, let's hope the power widget does too. But I need me proper battery stuff, so alas :).
I was thinking about trying it out due to issues I have been reading about with the updated version of CWM I only really use it to name my backups, thanks for the quick responses guys, one more quick question about today's build of CM 10 due I need to flash SU or is it in the build now
In the build, just update the binary post-flashing.
Status bar stuff works, but if you choose to use the 7/17 GAPPs package from goo-inside.me, you'll need to reinstall Gmail and Maps. But only one gallery, thank God. lol
i think we had to do same with the 4/29 GAPPS for aokp, no?
any idea if market restore is working?
Yes to the first, no idea to the second.
For the first, it's compliant with new Google licensing and stuff.
Hey guys... a little off topic, but I was wondering if you can point me in the right direction, if there is a "Right Direction". I just picked up a Asus Infinity T700 and it comese with ICS 4.0.3. My question is... BEFORE I install my apps and get things the way I like it... Is it possible to Root and/or Hack a tablet....? and if so, are the developers designing Jelly Bean for Tabs yet....?
Again, sorry about the off topic question.. thanks for any direction you can provide...
Another nice jb mod. Asst lockring mods. The guy has a ton of different ones. Even though aokp not here yet, I'm getting ready.
http://rootzwiki.com/index.php?/top...,-CM's-CID,-Superheroes-and-more!#entry750520
Jellybean, Tapatalk2, and the Galaxy Nexus FTW!! ;)
Reactions: JkdJedi
Nammna
