[GUIDE][8/1] Jelly Bean Now! Resources & Discussion
Re: [GUIDE][7/12] Jelly Bean Now! Resources & Discussion
Mine was doing that as well. Go into phone settings, language and input and then select swiftkey, then hit the menu button next to it. That should take you back into Swiftkey where it was crashing and let you move forward. At least it worked for me.
You sir, are a genius!! That did it. Thank you!!
Welp... there ya go then, lol :)
decided to wait on CM 10 until I'm not frantic to get it flashed and have a cold beverage to help me out; hoping the new update will be out by then :-)
so are there major differences between Jake JB and CM10? i am running smooth with what I have but if its green on the other side.. well than let the flashing begin. lol!
link to cm10 please
Xanth
Can anyone link me to CM10? Idk where it is on the thread. I have gapps. Just need the new nightly
link to cm10 please
Xanth
euroskank
wait until the new nightly comes out later today, with all the merged CM9 goodies
if I change to CM10, is there a order list on the correct way to flash the rom?
I read it comes with gapps in the rom.. correct?
no need to install a su file if I have a JB rom installed?
Sorry but changes for a noobie are difficult at times, only flashing for 2 months now and liked ICS by AOKP, than did the JB Jake, now everyone is hot on CM, so I guess its the bomb now, lol!
im not sure about gapps... yesterday's release didnt have it, but i read that tonight's may (which is weird, because i thought gapps had to be segregated)
as for the process... same thing: nandroid, wipe cache/dalvik, format system, wipe data, flash CM, flash gapps (depends on comment above), reboot. here's the change: go into Superuser app, and update the binary. it will say that 3.2 is installed, and 3.1.1 is the most recent. its weird, but as dm mentioned a few posts ago, its correct
one thing i should mention, my experience with CM10 and Kejar's 7/15 gapps did not restore apps from Play. the app i use to restore my apps/data does not work with the new clockwork method of backup, so i couldnt restore my SMS/Apps. so, tread cautiously.
Reactions: 2defmouze
Ok I check my phone I only have supersu app, not a superuser app, guess its a different app that I need to get from play.goggle, I was use to reinstalling my apps after the clean wipe to JB3.x as we were all asked to do a clean install.
I use sms back up for texts, and nova to redo my screens, I dont really save anything and doing a wipe my pic, songs, etc all stay anyway. just the time to DL all the apps again sux!
superuser and supersu are just different apps. back when i was on AOKP, i had superuser (though i think that came from my rooting process, not the ROM). when i switched over to the JB ports, everyone was using SuperSU.
CM10 comes with the Superuser app instead of SuperSU.
happy flashing! i think i will give CM10 another whirl tonight, now that i got my SMS backed up using SMS Backup +
Reactions: Xanth269
Will I be able to dirty flash this build to the ones with goodies? Or will I have to re setup and stuff?
should be able to dirtyflash coming from another cm10 nightly. i will echo the advisers here - you can DF, but should something go wrong, you should try to clean flash
Exactly. DF if you want.. If you get errors, FCs, etc.. You know what to do ;)
Just my 2 pennies but....
Not that I have done a lot of flashing but was told when switching rom to do a "clean" install to avoid issues.
Xanth
Xanth
ROM to ROM, or nightly to Milestone of same ROM yes, should do clean
nightly to nightly of the same ROM, can do dirty
Always depends.. Even a nightly can change just enough that dirty gives you problems. All depends on what exactly changes in the system.
Reactions: zero neck
heritagevine14
