[GUIDE][8/1] Jelly Bean Now! Resources & Discussion
Can some one point me in the direction to get TWRP I can't find it anywhere
Re: [GUIDE][7/12] Jelly Bean Now! Resources & Discussion
GRAWWHHHHH still no market restore.... WTFFFFF
ok, thats that. now to continue setting up CM10 and push my apps
Not working on Jelly Belly 2.6 :(
phew, finally got CM10 & nova set up.... i look forward to dirty flashing for a while!
Jelly Belly 3.7 is out. Mostly bug fixes. New GAPPS
Meh, none of those bugs are in CM10. I'm staying put. Jake done good, CM10 done better :).
Reactions: 2defmouze
Only one way to find out :)
How did I know you would say that lol
Edit: what I meant to say was can I access it like I do CWM or do I have to be in recovery to use it, sorry about that lol
You have to run it through zipthemer first. You did that right?
Should work after that.
Jellybean, Tapatalk2, and the Galaxy Nexus FTW!! ;)
Followed the steps below and nada... will try again after a couple of beers ;)
Alternative for JB:
0.Do a Nandroid backup
1.Download Desired image/zip and place it somewhere on your sdcard
2.Download and open ZipThemer
3.Hit Settings
4.Hit Edify
5.Hit Browse...and find the Rom.zip that you are currently using
6.Hit Configure...
7.Hit +Theme(find your image.zip)
8.Hit Build it!
9.Reboot into recovery
10.Install the zip that you just created should be on the root of the sdcard ending in -update.zip
Please...
link for CM and are the gapps on the same page or get it off goo?
EDIT: found this link :http://fitsnugly.euroskank.com/?rom=cm10&device=toro
but whats the difference between toro and torplus?
and are gapss from 1 dev team compatible with another dev team, i.e. CM and JakeDay?
Please...
Toro plus is the Sprint Galaxy Nexus and you are able to use Jakes gapps with CM you could also use Kejars as well
sukarisw12
