[GUIDE][8/1] Jelly Bean Now! Resources & Discussion
How's battery life? Does it come with a T9 dialer? Does it have better music effects than stock? Just asking cause these are all stuff I have on jelly belly 3.6 right now but thinking of flashing CM10 tonight
Yes it has a t9 dialer and it has dsp manager. No offense to Jake, but he's nowhere near the CM devs.
Battery life has been great for me. I posted a bunch of screens yesterday, be sure to check them out.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Re: [GUIDE][7/12] Jelly Bean Now! Resources & Discussion
wow... i JUST finished downloading the 7/19 8AM nightly, and lo and behold, theres a newer 7/19 nightly
time to find a starbucks with wi-fi.... trying to download 140MB over spotty 4G is not fun
Downloading and flashing.
Also, going to be using Kejar's GAPPs for now on, until another package comes out that I like.
Because of this.
Also, the changelog appears to remove the "WIP" (work in progress) from the power widget. Will confirm if LTE works as soon as it's flashed.
got a link to kejar's handy? i have a 714 gapps file on my phone, just cant remember if it was kejars
Reactions: DB12088
Dmmarck when flashing using TWRP is it basically the same process as flashing through recovery or is there anything different I need to do
Yup. I do a little clockwise motion, starting at cache, then dalvik, then system for a dirty flash. Then I do rom then GAPPs. You can do a queue too--"add another zip." LOVE that feature.
thanks.... blah, so what was the new build for
It appears to fix an issue with systemui crashing when putting sync (not to be confused with LTE toggles/data) in the power widget/toggles.
Reactions: DB12088
Thank you sir I am about to flash CM 10 and didn't want to bork my phone
Loving the new Power Widget UI BTW:
CM10
CM9
Ok last question. I know I'm bugging you a lot today. But just want to make sure I get everything ready for the flash of CM10. What Gapps do I use with CM10 and does it auto redownload my apps or am I going to have to re download them one at a time one by one again?
I've heard that a variety of GAPPs packages will do that, but those that profess auto restore capabilities seem to do it..intermittently.
I recommend the 7/15 GAPPs package. That's a couple pages back or so (or maybe last page).
You may have to do it one by one, but if you stay on CM10 that'll be the last time you do that :).
Reactions: craigrn16
Ok I downloaded CM10 and damn you were right. This Rom is waay better than Jelly Belly. for some reason when I try to go to Titanium back up I keep getting super user permission over and over. Any idea whats going on? Actually I don't care why its happening any idea how to fix it?
Update the binary :).
Welladjusted
