[GUIDE] Guide to Unlocking & Rooting the HTC Rezound
Ok, WEll I am a total newb at this... ANy chance you can help walk me through it?
Sure... Remember this requires Windows 7/Vista/XP or Linux, it will not work in Win 8/8.1. Do you have adb installed and working? If not, you should start there
Sent from my Nexus 4 using Tapatalk
I have it installed and it seems to be running. I am not sure if there is something with the adk I should be building
You don't... All you really need is the platform-tools directory. Open a command window in that directory start the phone and start fastboot then type
fastboot devices
If it doesn't recognize your device, you probably have a driver problem.
fastboot devices
I have no idea how to use the tools you are talking about
Which part didn't you understand? Command window (ie. CMD prompt) or the fastboot command?
I think I am doing the process wrong. I have a feeling there is a command window within the programs downloaded I need to use. Not just the regular windows command prompt.
No, regular CMD window, just have to be in the proper directory.
shift Right click on directory (folder) and select Open Command Window here... Or with CD commands.
TheGreatApe00
