[GUIDE] Guide to Unlocking & Rooting the HTC Rezound
Re: Custom Recovery & Rooting the HTC Rezound
Well I discovered one idiot move on my part but the end result was the same. I forgot to add the extension .zip to the file name. I received considerable more scrolling green script this time but it never stopped to get a "yes" from me. It went back to the HBOOT screen.
What to do now????
Re: Misc. Tools for the HTC Rezound
Oops. Quoted the wrong post but can't figure out how to delete this second msg. Sorry.
I downloaded my Titanium and when opened it said I wasn't rooted.
Only way to root now is to use a combination of Amon-Ra and superuser from the market.
Download and install Amon-Ra Custom Recovery
Reboot into recovery
Under the developer menu install Superuser
Reboot the phone normally
Download Superuser from the Android market
Profit
Reactions: Dugoutdog
Profit
I'll try first thing in the morning. I just woke up and am now off to work.
Thanks.
Profit
Well I did it this am. I downloaded the Latest version 3.14 of Amon-Ra recovery "recovery-ra-vigor-3.14-gnm.img" from the XDA website. Compared your instructions and their's and they were virtually identical. After reboot I opened up my Titanium Backup Pro and I found myself rooted. I can't thank you enough for your help.
I'm going to likely install a custom ROM in the near future and I was wondering . . . there has been lots of talk around various forums that the Amon Ra was more stable and all around better (at this point anyway) than ClockWorkMod. I have ROM manager on my phone. Is there an Amon-Ra program like it or all ROM's installed through HBOOT? (that's a guess - remember I'm new to most all this.
Nope, CWM uses ROM Manager and there's no equivalent app for Amon-Ra. If you talk to Dovahkiin, he'll tell you that CWM is stable in it's current form. And it is. It just doesn't do the rooting bit you just went through. So feel free to flash the latest CWM but be aware that there are a few common complaints(not being able to initiate a backup, restore a backup due to md5 issues, not charging while the phone is off). As far as I know Dovahkiin has the whole shebang working without issue...
Sometimes I shouldn't think too hard when I get home from work. I referred to CWM and shouldn't have (it was a busy night at work - damn Apple iPads - I work for FedEx who moves all of Apple's stuff. Picture 17 53' long trailers full of iPads arriving for download, sort, and a flight . . . and that was only for the Rocky Mtn's west).
So I'll start again. I have ROM manager installed. Is it compatible with Amon Ra for downloading/installing ROMs? I assume if I flash a ClockWorkMod recovery it will replace Amon Ra with itself ?? If it does then how do you flash a recovery with Amon Ra?
No worries.... No ROM Manager doesn't work with Amon Ra. Only CWM works with Amon Ra. If you want to flash CWM over Amon Ra simply get the latest CWM download, and flash it in HBOOT similar to the way you flashed Amon-Ra. It will overwrite the recovery partition with CWM and you can go on using ROM Manager.
I am not sure if this is the right place to ask this...I am thinking about taking advantage of the current Verizon deal for the Rezound. I would be coming from a rooted Droid X. I can't imagine having a phone that I can't root. The latest OTA for the Droid X prevents root and SBF. I didn't take it, so I am still good with the Droid X. My question is, has anything similar been done to the Rezound, I would hate to get one and find that root is not possible.
Yes you can still root the Rezound. You have to unlock the phone via HTCDev.com but it's well worth it.
stuck on black screen with triangle exclamation point!
A little more info may be helpful. Did you try unlocking and its stuck? Did you try flashing a recovery and its stuck? Did you light it on fire and its stuck? Help us help you....
Started the process to root my Rezound tonight and was doing ok until I hit a snag..
I unlocked successfully using HTCDev
Grabbed the AmonRa recovery file and put it on the root of my external card, named appropriately
Booted to HBOOT
[snag] Main Version is older???
OK, what do I do now?
Booted to HBOOT
I'lll add this to my FAQ. HTC Misctool [Tool to read/write main version] - xda-developers
The alternate is to flash it manually using fastboot as described here: http://forums.androidcentral.com/re...66392-guide-unlocking-rooting-roming-faq.html
Hello. Having an issue flashing amon ra. I have unlocked my resound. When issuing the commands in command prompt it advises me not found. Used the Mr Smith how to guide and I verified that the files for Google dev are in my directory. Thinking about starting from scratch.
I'm certainly not an expert with command prompts but it sounds like maybe your not in the right directory.
"Command Not Found" errors typically mean you're not in the right directory. if you type dir in a command prompt you should see the file(s) you're referencing.
You have two options.
Change directory to wherever your command files are:
Code:
cd \androidsdk\platform-tools
fastboot flash recovery <path to>\recovery.img
OR
Reference everything by path
Code:
c:\androidsdk\platform-tools\fastboot.exe flash recovery <path to>\recovery.img
In either case, change <path to>\recovery.img to where your amon ra img file is.
uOttawaGrad_22
