[GUIDE] Guide to Unlocking & Rooting the HTC Rezound
"Command Not Found" errors typically mean you're not in the right directory. if you type dir in a command prompt you should see the file(s) you're referencing.
You have two options.
Change directory to wherever your command files are:
Code:
cd \androidsdk\platform-tools
fastboot flash recovery <path to>\recovery.img
OR
Reference everything by path
Code:
c:\androidsdk\platform-tools\fastboot.exe flash recovery <path to>\recovery.img
In either case, change <path to>\recovery.img to where your amon ra img file is.
Missing the easy stuff I think. C:android exists. Android SDK and fastboot in dir. As is recovery. Typed commands and still stating cannot find file specified
Code:
type dir *.img
You should see something like this:
Code:
c:\scripts\Android\Zips\Recovery>dir *.img
 Volume in drive C is OSDisk
 Volume Serial Number is E4A6-6D8A
 Directory of c:\scripts\Android\Zips\Recovery
01/25/2012  12:36 PM         7,352,320 recovery-ra-vigor-3.10-gnm.img
               1 File(s)      7,352,320 bytes
               0 Dir(s)  225,181,888,512 bytes free
Then you should be able to do:
Code:
fastboot flash recovery recovery-ra-vigor-3.10.gnm.img
Where did you install the AndroidSDK into? You would've used this directory when you unlocked your phone.
Ok so your command would be
Code:
"C:\program files (x86)\android\android-SDK\platform-tools\fastboot.exe" flash recovery <path to>\recovery.img
Make sure to include the quotes. and change <path to>\recovery.img to wherever you stored your Amon Ra image file
Amon ra is in multiple places. My android folder and Went to my user/download folder.c:users\thetaterpatch\downloads
OK then do this:
Code:
"C:\program files (x86)\android\android-SDK\platform-tools\fastboot.exe" flash recovery c:\users\thetaterpatch\downloads\<your amon ra.img>
Reactions: Pdtate
Dunno how I am managing to mess this up. Unlocking was supposed to be the hard part. Still getting path not found. Is the Dr1vers one click reliable?
No clue, I've never used a one click. All you're doing is mistyping the command. Since we know the first part should be right you can type :
Then drag the recovery image file on to your command window. It will type the rest for you. All you have to do is hit enter.
Reactions: Pdtate
So, is there an option to switch between amon ra and stock recovery??
How?
Sent from my ADR6425LVW using Android Central Forums
I have downloaded all the requirements for the unlock but it wont work. I get to the cmd command point and cant get it to recognize the path
I get to the cmd screen and it keeps saying that the path is not recognized.
I am assuming you mean one of the fastboot commands? Sounds like you are not in the correct directory...
It should look something like this:
Code:
C:\adt-bundle-windows-x86_64-20131030\sdk\platform-tools>fastboot oem get_identifier_token
If you are getting an invalid path error, then you do not have the command structure correct for your directory structure
TheGreatApe00
