[GUIDE][MAC/PC/LINUX][4.2] Unlock, Root and Flash Recovery
Re: [GUIDE] How to Unlock and Root the Nexus 7
No, I wrote it as
fastboot-mac reboot
Should I try that?
Just tried it and same message:
'No such file or directory'
I was in the same boat. I know the update we did threw everything off. I know what I am doing, and have done things like this on my OG Droid and Galaxy Nexus. Clockwork mod just wasn't working right with my tablet.
I went back to stock, and rooted. I, too, will wait for a recovery from clockwork mod before I proceed.
Do you mean you had the same problem with getting the Nexus 7 to reboot from Terminal?
Silken, is your super boot folder on the desktop?
If so try this pls
~/desktop/r1-nexus7-superboot/ fastboot-mac reboot devices
Reactions: 2defmouze
If so try this pls
(Apologies am a complete newbie to Android)
I copied this into terminal and it is saying it is a directory. Should I browse to this?
Enter this in terminal now
~/desktop/r1-nexus7-superboot/ adb-mac reboot bootloader
If that doesn't work, you can power down the phone by using volume keys to navigate to power down, and select with power key.
Wait I screwed up above
The first post I posted for ya
Wait A sec.
~/desktop/r1-nexus7-superboot/ fastboot-mac reboot bootloader
That's the command :)
Or, now gthat it says is a directory, you can try this again
./ fastboot-mac reboot bootloader
Or
./adb-mac reboot bootloader
Don't worry its Fine. Use the volume keys on the tab to power down
Ok, bloomin thing. Right, so am I powering off or restarting bootloader?
After this, can I continue to root the device?
Yeah try the reboot commands first, if no luck, power down.
Then, you can just power back up in boot loader mode again and root it :)
You can also power down by holding power in the boot loader mode I believe
Got this:
* daemon not running. starting it now *
* daemon started successfully *
error: device not found
Am I ok just to power it off and then switch back on using the volume keys?
Got this:
Yes
jipeve
