[GUIDE] Nexus 7 - Factory Image Restore
Ok, so I go to the google website to download the factory image. I click on the link and when I do so it saves the file as nakasi-jzo54k-factory-973f190e.tar, not nakasi-jzo54k-factory-973f190e.tgz. I've tried it on my pc, my nexus 7, and my HTC. Everyone of them saves it the same way. My computer doesn't even know what to do with a .tar file. If you need more info just let me know and I'll answer if I can. Thanks
Can you use 7zip to extract..?
I don't understnad how to get the fastboot drivers. I have looked around the internet for a while :/
Look in the Unlock and Root guide..
"bootloader-grouper-4.18.img
sending 'bootloader' (2096 KB)...
FAILED (remote: Bootloader is locked.)
how do I unlock bootloader? my nexus 7 won't boot past x logo.
Thanks!
Thanks!
If your bootloader is locked then why are you doing this procedure? This is to get your device back up and running after you already screwed something up while hacking away at it, lol :)
( sorry for my eng )
After do all the steps - i can't login normal. My N7 stop in finding wifi and no more step to choose.
How can i fix that ?
I do 3 ways but nothing can sold this problem:
1) After you finish the process in fastboot and the device begins to reboot... immediately unplug it from the computer and sit patiently. See if giving it at least 5-10 minutes makes a difference. Also check the md5 checksum of the image you downloaded and make sure it matches what is given for the file on Google's site
2) After the full flash and still getting bootloops... I'd say try unzipping the main image zip (image-nakasi-jro03d.zip) and flashing JUST the system from the bootloader, i.e. only do:
Code:
fastboot flash system system.img
3) Have you tried the following:
(1) Ignoring all of the partition wipes featured in the guide. No reformatting, repartitioning. Try immediately locking and unlocking the device before you get to flashing.
(2) Then flashing the stock images
I bought my N7 to a Tablet Service - they can fix that but when i Reset it to factory - the problem return. I don't want to loose money with Tablet Service again.
My Nexus 7 can run Ubuntu 12.10 Touch Preview very well - i have just tried. ( In recovery - install 2 zip files )
2.4 - i solve th? problem - my wifi network has a problem
I'm currently stuck in the android bootloader and cannot proceed. All the fastboot commands to erase data, recovery, system etc...work perfectly, however I cannot get it to "flash bootloader grouper 4.18.img". It says "unknown partition "bootloader-grouper 4.18.img" then directly under it "error:cannot determine image filename for bootloader-grouper 4.18.img".
I've tried both 4.1.2 and 4.2.2 links, extracted everything to platform tools. Everything should be good to go I just cannot get past this part. Any help would be greatly appreciated.
Thank you for this info. I erased my nexus 7 completely and was left with no os. It was pretty easy to get it baxk up and rumming
You're actually supposed to type it like this:
fastboot flash bootloader bootloader-grouper-4.18.img
"Currently trying to return to stock an unlocked, Nexus 7 using a pacman ROM flashed via goomanager by my brother, but is having a lot of force errors and crashes"
I'm stuck here "waiting for device"......whenever I connect the Nexus 7 to the computer, I get a popup saying Windows doesn't recognize the device.
edit---- never reading back need to see if i installed the fastboot drivers
Ok so I have to be somewhat retarded. I booted my Nexus 7, connected via USB to PC. Made sure that USB debugging was enabled to allow adb.
I went to device manager, found the Nexus 7, updated the driver to Universal Naked Driver 0.72 found [ADB/FB/APX Driver] Universal Naked Driver 0.72 - xda-developers
It updated the driver just fine.
I now turn the Nexus 7 off, boot into bootloader."Fastboot mode" is red. Lock state - Unlocked. Whenever I connect it via USB to PC, I'm getting the uanble to recognize device error, and when in command prompt doing the "fastboot devices" command, nothing shows up, so clearly I haven't installed the drivers correctly. Am I missing something?
Edit AGAIN --- I thought I installed the Universal Naked Driver 0.72 correctly, but it shows that the Windows drivers are installed and won't let me install the UND.
I am attempting to install the android_winusb
But I get this error
One of these days Microsoft might figure out USB. I would get Wug's Toolkit from xda-developers forum for the Nexus and start over. Good directions built in. Use the pda drivers. You might have to try more than one time but the toolkit has always worked for my N7 and N10.
Sent from my Nexus 10 using Tapatalk HD
Hmmm ok I got all the way down to here
C:\Users\Beast\Desktop\android sdk platform\platform-tools>fastboot reboot-bootl
oader
rebooting into bootloader...
OKAY [ 0.020s]
finished. total time: 0.021s
C:\Users\Beast\Desktop\android sdk platform\platform-tools>fastboot -w update im
age-nakasi-jdq39.zip
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
archive does not contain 'system.sig'
Bootloader Version...: 4.18
Baseband Version.....: N/A
Serial Number........: 015d256443481c0b
checking product...
OKAY [ 0.040s]
checking version-bootloader...
OKAY [ 0.023s]
sending 'boot' (4944 KB)...
OKAY [ 0.593s]
writing 'boot'...
It's been stuck at writing boot for over 5 minutes....Do I exit out of command prompt? Do I unplug Nexus? I feel like i'm going to brick it if I do either one.
oader
OKAY [ 0.020s]
checking product...
OKAY [ 0.040s]
OKAY [ 0.023s]
OKAY [ 0.593s]
writing 'boot'...
Reboot straight to the bootloader and try sending the pieces individually. I've had a few people do that with success, see earlier in the thread.
The boot part it is stalling at is just the stock kernel, won't brick if you boot back to bootloader and try again. Also you may just need to reinstall the drivers or even simply try a different usb port (rear ones are best). Do that first in fact :)
Hmm I did try moving to the rear, it did help. I'll try switching to a different rear port. Then I'll try installing the drivers all over again, thanks!
Tried doing things one-by-one manually, but I get stuck at "fastboot erase userdata"
c:\android sdk platform\sdk\platform-tools>fastboot erase boot
erasing 'boot'...
OKAY [ 0.773s]
finished. total time: 0.774s
c:\android sdk platform\sdk\platform-tools>fastboot erase cache
******** Did you mean to fastboot format this partition?
erasing 'cache'...
OKAY [ 0.679s]
finished. total time: 0.681s
c:\android sdk platform\sdk\platform-tools>fastboot erase recovery
erasing 'recovery'...
OKAY [ 0.637s]
finished. total time: 0.638s
c:\android sdk platform\sdk\platform-tools>fastboot erase system
erasing 'system'...
OKAY [ 0.802s]
finished. total time: 0.804s
c:\android sdk platform\sdk\platform-tools>fastboot erase userdata
erasing 'userdata'...
Got to this part, which is further than I've ever gotten and still stuck at erasing userdata
c:\android sdk platform\sdk\platform-tools>fastboot -w update image-nakasi-jdq39
.zip
checking product...
OKAY [ 0.030s]
OKAY [ 0.019s]
OKAY [ 0.584s]
writing 'boot'...
OKAY [ 1.003s]
sending 'recovery' (5446 KB)...
OKAY [ 0.646s]
writing 'recovery'...
OKAY [ 1.181s]
erasing 'system'...
OKAY [ 0.934s]
sending 'system' (471804 KB)...
OKAY [ 54.565s]
writing 'system'...
OKAY [ 29.695s]
erasing 'boot'...
OKAY [ 0.773s]
erasing 'cache'...
OKAY [ 0.679s]
OKAY [ 0.637s]
erasing 'system'...
OKAY [ 0.802s]
.zip
checking product...
OKAY [ 0.030s]
OKAY [ 0.019s]
OKAY [ 0.584s]
writing 'boot'...
OKAY [ 1.003s]
OKAY [ 0.646s]
OKAY [ 1.181s]
erasing 'system'...
OKAY [ 0.934s]
OKAY [ 54.565s]
writing 'system'...
OKAY [ 29.695s]
That's odd.. I would just keep trying really, maybe with a new usb cable too. You can skip the other steps when you try again and only enter
Code:
Because that's the part we want to wipe. Theoretically if you can ensure that it erases it properly and the important bits like your kernel (boot), system and recovery were successfully written, you may be able to boot up and the OS should populate the empty userdata space automatically.
erasing 'boot'...
OKAY [ 0.773s]
erasing 'cache'...
OKAY [ 0.679s]
OKAY [ 0.637s]
erasing 'system'...
OKAY [ 0.802s]
.zip
checking product...
OKAY [ 0.030s]
OKAY [ 0.019s]
OKAY [ 0.584s]
writing 'boot'...
OKAY [ 1.003s]
OKAY [ 0.646s]
OKAY [ 1.181s]
erasing 'system'...
OKAY [ 0.934s]
OKAY [ 54.565s]
writing 'system'...
OKAY [ 29.695s]
I am also stuck here. I have done this 3-4 times and I get stuck here everytime. I have waited like 30+ minutes everytime, so I am assuming that is pretty long and something isn't going right.
Not sure what to do... :-/
Another edit: I stopped it again and I went with "fastboot erase userdata", just to see. I already tried it before like that, but why not try again.
Nazeer zaheen
